Sampling with replacement in Matlab
  • Topic: MATLAB
  • Thread starter Thread starter Dustinsfl
    Matlab Sampling
9 replies · 4K views
Dustinsfl
I am trying to simulate the probability of rejecting a good batch for a probability of \(0.94\) using the Binomial Probability Law.
My two cases are
P[k\geq 95] = \sum_{k = 95}^{100}\binom{100}{k}p^k(1 - p)^{100 - k}
and
P[k\geq 98] = \sum_{k = 98}^{100}\binom{100}{k}p^k(1 - p)^{100 - k}
I am not sure with what the question wants me to do so I plotted the both curves from \(p = 0.9\) to \(p = 0.99\).
Code:
clear all
close all
p = (0.9:0.001:0.99);                 % probability range
P = zeros(length(p), 1);              % pre-allocating P
PP = zeros(length(p), 1);            % pre-allocating PP
T = zeros(length(p), 1);              % pre-allocating T
TT = zeros(length(p), 1);            % pre-allocating TT
% only allowing 5 defective
for i = 1:length(p)
    for n = 95:100
        T(n, 1) = nchoosek(100, n)*p(i).^n.*(1 - p(i)).^(100 - n);
        P(i, 1) = sum(T);
    end
end
figure(1)
plot(p, P)
grid on
% only allowing 2 defective
for j = 1:length(p)
    for n = 98:100
        TT(n, 1) = nchoosek(100, n)*p(j).^n.*(1 - p(j)).^(100 - n);
        PP(j, 1) = sum(TT);
    end
end
figure(2)
plot(p, PP)
grid on
My two cases are
and
Code:
clear all
close all
for i = 1:length(p)
    for n = 95:100
        P(i, 1) = sum(T);
    end
end
figure(1)
plot(p, P)
grid on
for j = 1:length(p)
    for n = 98:100
        PP(j, 1) = sum(TT);
    end
end
figure(2)
plot(p, PP)
grid on
Code:
--> p=0.94;  %failure rate
--> N=10000; %number of simulated batches to test
--> ss=rand(N,100); %N samples of batches of size 100
--> sm=sum(ss'>p);  %number of failures in each batch
--> Pest=sum(sm>=5)/N %proportion of batches with 5 or more fails
Pest =
    0.7222
I have two questions then.
  1. Can you explain sum(ss'>5)? What does the ' do?
  2. This tells us 72% of batches will have 5 or more defects. How does that relate to good batches that are rejected? From my code, we know that 45% of time we accept a a defective batch. So 65% we have good batches. Is the answer then 72 - 65 = 7% of good batches are rejected?
Your question is ambiguous, I read it as the population has 94% good and 6% bad, what is the probability of rejecting a batch of 100 when the rejection criterion is that it have 5 or more defective items.
For questions about what Matlab commands do use the help system of try them out at the console (with small arrays).
the question is what is the probability of rejecting a good batch with that criteria.
What does "good batch" mean?
A batch with 5 or less defects. I am trying to find the probability that we reject a good batch of thousand when we only test a 100.
Please post the original question with the exact wording as asked.
Use a computer to simulation to determine the probability of rejecting a good batch. To simplify your code, assume sampling with replacement. A good batch is defined as one with a probability of obtaining a good chip p=0.95. The two strategies are to accept the batch if 95 or more of the 100 samples are good and if 98 or more are good.
I see no mention of a population or batch of size of thousand, where did that come from?
That is exactly what the original code I posted does (except I was using p=0.94 which is what you posted in your oringinal post).
Doing exactly the same but with p=0.95, and in SciLab rather than Matlab:
Code:
-->p=0.95;
-->N=10000;
-->ss=rand(N,100);
-->sm=sum(ss>p,2);size(sm)
 ans  =
    10000.    1.
-->Pest=sum(sm>=5)/N
 Pest  =
    0.5642
I would strongly suggest you practice posting questions as they are asked, and include any side information in the section of the book/lecture pertaining to the question. Otherwise you are just wasting the time of anyone foolish enough to try helping you (but then I knew that before replying didn't I).As I have just installed it, here it is in Octave:
Code:
octave:8> p=0.95;N=10000;
octave:9> ss=rand(N,100);
octave:10> sm=sum(ss'>p);
octave:11> Pest=sum(sm>=5)/N
Pest =  0.56080
