Scaling Augmented Matrices: Is My Thinking Correct?
2 replies · 3K views · last reply
jeremy222
An augmented matrix scaled by a number also means the solutions set is scaled by that same number. I believe this is true due to it basically being the same as elementary row operations preformed on each row. Unless it is a zero scalar in which case you lose all conditions. Is my method of thinking about this correct? Its not homework but I think it would help me understand a concept.
No, that's not true. If you have an augmented matrix, say
[tex]\begin{bmatrix}a & b & c & j \\ d & e & f & k \\ g & h & i & l\end{bmatrix}[/tex]
That is equivalent to the three equations ax+ by+ cz= j, dx+ ey+ fz= k, gx+ hy+ iz= l.
It is also equivalent to the matrix equation
[tex]\begin{bmatrix}a & b & c \\ d & e & f \\ g & h & i \end{bmatrix}\begin{bmatrix}x \\ y \\ z\end{bmatrix}= \begin{bmatrix}j \\ k \\ l\end{bmatrix}[/tex]
"Scaling" the augmented matrix by a number, multiplying every row by that number, gives multiples of the same equations which have the same solutions. If you multiply the coefficient matrix in the second form by a constant, but not the right hand side, that will divide the soluutions by the number.
one can look at the 1x1 case:
[a][x] =
if we multiply by 2, let's say, we get:
[2a][x] = [2b].
suppose a ≠ 0. then in either case, we find:
x = b/a, the solution to the 2nd equation is NOT x = 2(b/a).
it is exactly the same for
Ax = b, where A is a matrix, and b is a vector.
if A is invertible, x = A-1b.
and 2Ax = 2b has the same vector solution.
in other words, multiplying an equation on both sides by a number,
doesn't change the solution set for that equation.
if ax + by + cz = d, then for any number m:
m(ax + by + cz) = md, for the same x,y and z.
