Scherrer Equation Question (XRD)
  • Thread starter mesogen
    Xrd
15 replies · 79K views · last reply
mesogen
Hello,
I came to this forum looking for an answer to a pretty simply question about the Scherrer equation for peak broadening in the XRD pattern.
I understand that the full-width-half-maximum of the peak must be in radians, but when I measure the FWHM, it is in 2 theta. Do I need to half it to theta before plugging it into the equation? This is important because doing so doubles the answer you get for crystal size.
Thanks for any help.
Yes, you need to write the peak width in units of theta, not 2-theta.
Great! Thanks for that info!
So basically when I measure the peak width to be something like 2.5 (2theta) it is 1.25 (theta) and then convert that to radians so I can plug and chug?
I really appreciate the help!
mesogen,
I may have spoken in haste. I will need to see your Scherrer formula before I can say whether or not to divide by 2.
If I recall correctly, and it's been a while, if you have [itex]dcos\theta=K\lambda/w[/itex], w has units of 2-theta, and if you have [itex]dcos\theta=K\lambda/2w[/itex], then w has units of theta.
Let me confirm that with a text when I get a chance today.
I'm using the form that goes:
L = K*lambda / B*cos(theta)
where L = average crystal size (sorta)
B = the full width half maximum of the peak
But I was looking around online and nothing would tell me, but I think this page says that B is 2(delta)(theta)
http://www.eng.uc.edu/~gbeaucag/Classes/XRD/SathishScherrerhtml/SathishScherrerEqn.html
so I'm thinking maybe I should just take the degrees 2theta value and convert it to radians and then plug that into the equation.
I don't know. An answer like 20 nm seems just as reasonable as 40 nm to me.
Hi,
if you are using the formula as L= k*lamda/B*cos(theta)
your theta should be half of 2 theta, thete should be in degree (you may try rad as well, but not much different in the result you will get). e.g. a Bragg peak at 2theta 40, then theta is 20 degree.
Instead, B (usually you will take FWHM) must be in rad. The k constant varies from 0.8 to 0.98 depends on the crystalline shape.
Hope this will help.
Best regards
Hi,
I also use L= k*lamda/B*cos(theta) to calculate crystallite size and I convert B and theta in rad. The results I obtain are the same with those obtained using the XRD crystallite size calculator from the following link:
http://www.d.umn.edu/~bhar0022/dpcalculator/index.php
I think this is the right way to calculate L. By converting both B and theta into rad only the SI units are used
Best regards!
P.S Sorry about my poor english
kalun said:
Hi,
Best regards
Could you kindly let us know where your reference that you used to quote the numbers for for k?
i have 2th = 35.546 deg, d spacing 2.5236 A, fwhm 2 th - 0.148 deg, now can sombody put these values to get size of crystallite? i want to know the steps
thanks
Hello everybody,
I think I found a good paper that contains a good discussion about the values of K. My problem is that I don't have access to this paper and neither other persons I know. :cry:
I give you the link of the paper:
http://www3.interscience.wiley.com/search/allsearch?mode=citation&contextLink=blah&issn=1600-5767&volume=11&issue=&pages=102-113
Hope that somebody from this forum could download this paper and if it is possible I would also like a copy for me
Thanks in advance!
Hello,
From this thread I managed to answer all my questions, except one.
What is FWHM and how do I get the value for it?
Thanks
FWHM is full width at half maxima. So, first you find the maximum intensity of the peak (absolute value of max. intensity minus the base line intensity). Make half of this value. Find out the 2theta positions of the two points on the peak with this half-intensity value. The difference between these two 2-theta positions (not theta positions) is your FWHM. It will be in degree. Convert this deg value in radian, for using Scherrer equation.
In Scherrer equation, there is cos theta at the denominator. This theta is the value of the 2-theta position of max intensity divided by 2. Deg or radian does not matter since cos theta will be same.
In Scherrer equation, B is the measure of the broadening of the peak. B can be expressed in many ways. Simplest is FWHM. More accurate is Integral Breadth since it is calculated from the area of the peak, considering all the intensity points of the peak w.r.t base line.
There are two components in B measured in XRD peak. One is the broadening due to sample characteristics (crystallite size, lattice strain and defects). Another is Instrumental broadening which comes from the experimental parameters of X-ray Diffractometer. You can estimate B(Inst.) by measuring the broadening of a peak at similar 2-theta position of a standard sample provided with the diffractometer. This effect can be subtracted from measured B by various analytical ways. You can find this from published literature.
I have few publications in this field. If anyone needs some ref., I can provide mine. That will help.
