Scherrer Equation Question (XRD)
  • Thread starter mesogen
  • Tags
    Xrd
In summary, the peak width in units of theta, not 2-theta, needs to be plugged into the Scherrer equation to calculate crystal size.
mesogen
25
Hello,
I came to this forum looking for an answer to a pretty simply question about the Scherrer equation for peak broadening in the XRD pattern.
I understand that the full-width-half-maximum of the peak must be in radians, but when I measure the FWHM, it is in 2 theta. Do I need to half it to theta before plugging it into the equation? This is important because doing so doubles the answer you get for crystal size.
Thanks for any help.
Yes, you need to write the peak width in units of theta, not 2-theta.
Great! Thanks for that info!
So basically when I measure the peak width to be something like 2.5 (2theta) it is 1.25 (theta) and then convert that to radians so I can plug and chug?
I really appreciate the help!
mesogen,
I may have spoken in haste. I will need to see your Scherrer forumla before I can say whether or not to divide by 2.
If I recall correctly, and it's been a while, if you have [itex]dcos\theta=K\lambda/w[/itex], w has units of 2-theta, and if you have [itex]dcos\theta=K\lambda/2w[/itex], then w has units of theta.
Let me confirm that with a text when I get a chance today.
I'm using the form that goes:
L = K*lambda / B*cos(theta)
where L = average crystal size (sorta)
B = the full width half maximum of the peak
But I was looking around online and nothing would tell me, but I think this page says that B is 2(delta)(theta)
http://www.eng.uc.edu/~gbeaucag/Classes/XRD/SathishScherrerhtml/SathishScherrerEqn.html
so I'm thinking maybe I should just take the degrees 2theta value and convert it to radians and then plug that into the equation.
I don't know. An answer like 20 nm seems just as reasonable as 40 nm to me.
Hi,
if you are using the formula as L= k*lamda/B*cos(theta)
your theta should be half of 2 theta, thete should be in degree (you may try rad as well, but not much different in the result you will get). e.g. a Bragg peak at 2theta 40, then theta is 20 degree.
Instead, B (usually you will take FWHM) must be in rad. The k constant varies from 0.8 to 0.98 depends on the crystalline shape.
Hope this will help.
Best regards
Hi,
I also use L= k*lamda/B*cos(theta) to calculate crystallite size and I convert B and theta in rad. The results I obtain are the same with those obtained using the XRD crystallite size calculator from the following link:
http://www.d.umn.edu/~bhar0022/dpcalculator/index.php
I think this is the right way to calculate L. By converting both B and theta into rad only the SI units are used
Best regards!
P.S Sorry about my poor english
kalun said:
Hi,
Best regards
Could you kindly let us know where your reference that you used to quote the numbers for for k?
Hi,
From the courses I took during the M.S.C program I know that the value of k depends whether I take B=B1/2 or B=Bi where B1/2 is FWHM and Bi is the integral width of the diffraction line. When using B=B1/2, k=0.9 and k=1.05 for B=Bi. As far as I know Bi is more convenient for theoretical calculations.
Try the following reference:
http://books.google.ro/books?id=H-u...esult&ct=result&resnum=1#v=onepage&q=&f=false
i have 2th = 35.546 deg, d spacing 2.5236 A, fwhm 2 th - 0.148 deg, now can sombody put these values to get size of crystallite? i want to know the steps
thanks
Hello everybody,
I think I found a good paper that contains a good discussion about the values of K. My problem is that I don't have access to this paper and neither other persons I know. :cry:
I give you the link of the paper:
http://www3.interscience.wiley.com/search/allsearch?mode=citation&contextLink=blah&issn=1600-5767&volume=11&issue=&pages=102-113
Hope that somebody from this forum could download this paper and if it is possible I would also like a copy for me
Thanks in advance!
I don't know how I can get B .
Hello,
From this thread I managed to answer all my questions, except one.
What is FWHM and how do I get the value for it?
Thanks
FWHM is full width at half maxima. So, first you find the maximum intensity of the peak (absolute value of max. intensity minus the base line intensity). Make half of this value. Find out the 2theta positions of the two points on the peak with this half-intensity value. The difference between these two 2-theta positions (not theta positions) is your FWHM. It will be in degree. Convert this deg value in radian, for using Scherrer equation.
In Scherrer equation, there is cos theta at the denominator. This theta is the value of the 2-theta position of max intensity divided by 2. Deg or radian does not matter since cos theta will be same.
In Scherrer equation, B is the measure of the broadening of the peak. B can be expressed in many ways. Simplest is FWHM. More accurate is Integral Breadth since it is calculated from the area of the peak, considering all the intensity points of the peak w.r.t base line.
There are two components in B measured in XRD peak. One is the broadening due to sample characteristics (crystallite size, lattice strain and defects). Another is Instrumental broadening which comes from the experimental parameters of X-ray Diffractometer. You can estimate B(Inst.) by measuring the broadening of a peak at similar 2-theta position of a standard sample provided with the diffractometer. This effect can be subtracted from measured B by various analytical ways. You can find this from published literature.
I have few publications in this field. If anyone needs some ref., I can provide mine. That will help.
FAQ: Scherrer Equation Question (XRD)
1. What is the Scherrer equation and how is it used in XRD analysis?
The Scherrer equation is a mathematical formula that is used in X-ray diffraction (XRD) analysis to determine the size of crystalline particles in a sample. It takes into account the peak broadening in XRD patterns, which is caused by the size of the crystalline particles. By plugging in the necessary values, such as the peak position and the full width at half maximum (FWHM) of the peak, the Scherrer equation can calculate the average size of the crystalline particles in the sample.
2. What are the key assumptions of the Scherrer equation?
The Scherrer equation makes a few key assumptions in order to accurately determine the particle size. These assumptions include that the crystalline particles are spherical, they are randomly oriented, and they are free of strain and defects. In addition, the peak broadening should only be due to the particle size, and not other factors such as instrumental broadening.
3. How accurate is the Scherrer equation in determining particle size?
The accuracy of the Scherrer equation in determining particle size depends on how well the assumptions hold true for the sample being analyzed. In ideal conditions, the Scherrer equation can provide a fairly accurate estimate of the particle size. However, if the assumptions are not met, the results can be less accurate. It is important to consider the limitations of the Scherrer equation and to use it in combination with other analytical techniques for a more comprehensive analysis.
4. What are the units of the Scherrer equation and how should they be interpreted?
The units of the Scherrer equation are in length, typically in nanometers (nm) or Angstroms (Å). This represents the average size of the crystalline particles in the sample. It is important to note that the Scherrer equation provides an average size and does not account for the distribution of particle sizes in the sample. Therefore, the results should be interpreted as an estimation rather than an exact measurement of the particle size.
5. Are there any alternative methods for particle size determination in XRD analysis?
Yes, there are alternative methods for determining particle size in XRD analysis. One popular method is the Warren-Averbach method, which uses a more complex mathematical model to account for multiple peak broadening factors. Other techniques, such as transmission electron microscopy (TEM) and dynamic light scattering (DLS), can also be used to measure particle size. It is important to choose the most appropriate method based on the sample and research goals.
