SCOPE_IDENTITY() returns numeric, not UNIQUEIDENTIFIER
1 reply · 4K views · last reply
SlurrerOfSpeech
Could use some help figuring out the error
Operand type clash: numeric is incompatible with uniqueidentifier
which points to the specified line below
Code:
CREATE PROCEDURE AddPartner
    @name NVARCHAR(50), @email NVARCHAR(254), @new_guid UNIQUEIDENTIFIER OUTPUT
AS
BEGIN
    SET NOCOUNT ON
    INSERT INTO Partners (name,email) VALUES (@name,@email)
    SELECT @new_guid = SCOPE_IDENTITY() -- specified line
    RETURN
END
The table Partners is of the form
Code:
CREATE TABLE Partners (
    id UNIQUEIDENTIFIER NOT NULL DEFAULT NEWID(),
    name NVARCHAR(50) NOT NULL,
    email NVARCHAR(254) NOT NULL, -- 254 is optimal length according to http://stackoverflow.com/questions/1199190/what-is-the-optimal-length-for-an-email-address-in-a-database
    PRIMARY KEY (id)
Any help in figuring out this error? What I'm trying to do is return from the procedure the guid that was just assigned to the row that was just inserted.
Code:
AS
BEGIN
    SET NOCOUNT ON
    RETURN
END
Code:
    PRIMARY KEY (id)
SCOPE_IDENTITY() doesn't work with guid fields.
Here they show how you could get the last inserted guid (haven't tested it).
