Second derivative relationships of substituted varaibles
This discussion focuses on the application of the chain rule to determine the relationships between the second derivatives of substituted variables in multivariable calculus. The variables are defined as r = 3x + y and s = x + (1/5)y. The participants confirm that the second derivative relationships derived from the chain rule are indeed correct, leading to the conclusion that ∂²/∂x² = 9∂²/∂r² + 6∂²/∂r∂s + ∂²/∂s². The conversation emphasizes the importance of correctly interpreting the application of differential operators on substituted variables.
  • Understanding of multivariable calculus concepts, specifically the chain rule.
  • Familiarity with differential operators and their applications.
  • Knowledge of variable substitution techniques in calculus.
  • Experience with interpreting second derivatives in the context of multivariable functions.
  • Study the application of the chain rule in multivariable calculus.
  • Learn about differential operators and their properties in the context of variable substitution.
  • Explore examples of second derivative relationships in multivariable functions.
  • Investigate the implications of cross terms in second derivatives and their significance in calculus.
Mathematicians, students of calculus, and educators seeking to deepen their understanding of multivariable calculus and the application of the chain rule in derivative relationships.
PhilDSP
I'm using variable substitution to solve a problem. Finding the relationships between the first derivatives of both sets is straightforward using the chain rule, but I'm uncertain if the way I'm determining the second derivative relationships is correct.
Given a description of a problem expressed in the x and y variables, I make the substitution as follows
r = 3x + y \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ s = x + \frac{1}{5}y
The chain rule gives
\frac{\partial}{\partial x} = 3 \frac{\partial}{\partial r} + \frac{\partial}{\partial s} \ \ \ \ \ \ \ \ \ \ \ \ \ \frac{\partial}{\partial y} = \frac{\partial}{\partial r} + \frac{1}{5} \frac{\partial}{\partial s}
Solving for \frac{\partial}{\partial r} and \frac{\partial}{\partial s} I get
\frac{\partial}{\partial r} = - \frac{1}{2} \frac{\partial}{\partial x} + \frac{5}{2} \frac{\partial}{\partial y} \ \ \ \ \ \ \ \ \frac{\partial}{\partial s} = \frac{5}{2} \frac{\partial}{\partial x} - \frac{15}{2} \frac{\partial}{\partial y}
Are the second derivative relationships from the chain rule then ?
\frac{\partial^2}{\partial x^2} = - \frac{1}{2} \frac{\partial^2}{\partial r^2} + \frac{5}{2} \frac{\partial^2}{\partial s^2} \ \ \ \ \ \ \ \ \frac{\partial^2}{\partial y^2} = \frac{5}{2} \frac{\partial^2}{\partial r^2} - \frac{15}{2} \frac{\partial^2}{\partial s^2}
Maybe this a strange example as the \frac{5}{2} \frac{\partial}{\partial y} and \frac{5}{2} \frac{\partial}{\partial x} in the separate equations seem to make the relationships symmetrical.
What are you differentiating?
There will be a function f(x, y) which is undefined at the moment because this example is only a mock up. So the differential operators operate on f(). Then the differential operators for the substituted variables also operate on f() as f(r, s).
That is to say \frac{\partial}{\partial x} \rightarrow \frac{\partial f}{\partial x} and \frac{\partial}{\partial r} \rightarrow \frac{\partial f}{\partial r}
No, you should have cross terms. Try taking \partial/\partial x = 3 \partial/\partial r + \partial/\partial s and applying it again. You should see that you get a cross term equal to 4 \partial^2/\partial r \partial s. Think about what happens when you multiply (3r+s)(3r+s).
Excellent hints Muphrid, thanks. But this is a bit tricky and I don't seem to have arrived at a result that is in sync with yours. Here is the breakdown:
The first order chain rule is
\frac{\partial}{\partial x} = \frac{\partial r}{\partial x} \frac{\partial}{\partial r} + \frac{\partial s}{\partial x} \frac{\partial}{\partial s} \ \ \ \ \ \ \ \ \ \ \ \ \frac{\partial}{\partial y} = \frac{\partial r}{\partial y} \frac{\partial}{\partial r} + \frac{\partial s}{\partial y} \frac{\partial}{\partial s}
The second order chain rule for x should be
\frac{\partial^2}{\partial x^2} = \frac{\partial}{\partial x} (\frac{\partial r}{\partial x} \frac{\partial}{\partial r} + \frac{\partial s}{\partial x} \frac{\partial}{\partial s})
\ \ \ \ \ \ \ = \ \ \frac{\partial r}{\partial x} \cdot \frac{\partial}{\partial x} (\frac{\partial}{\partial r}) \ \ + \ \ \frac{\partial}{\partial x} (\frac{\partial r}{\partial x}) \frac{\partial}{\partial r} \ \ + \ \ \frac{\partial s}{\partial x} \cdot \frac{\partial}{\partial x} (\frac{\partial}{\partial s}) \ \ + \ \ \frac{\partial}{\partial x} (\frac{\partial s}{\partial x}) \frac{\partial}{\partial s}
Then the results would seem to be\frac{\partial^2}{\partial x^2} = \ \ 3 \cdot [3 \frac{\partial}{\partial r} + \frac{\partial}{\partial s}] \frac{\partial}{\partial r} \ \ + \ \ [3 \frac{\partial}{\partial r} + \frac{\partial}{\partial s}] (3) \frac{\partial}{\partial r} \ \ + \ \ 1 \cdot [3 \frac{\partial}{\partial r} + \frac{\partial}{\partial s}] \frac{\partial}{\partial s} \ \ + \ \ [3 \frac{\partial}{\partial r} + \frac{\partial}{\partial s}] (1) \frac{\partial}{\partial s}
\ \ \ \ \ \ \ \ = \ \ 9 \frac{\partial^2}{\partial r^2} \ \ + \ \ 3 \frac{\partial^2}{\partial r \partial s} \ \ + \ \ 9 \frac{\partial^2}{\partial r^2} \ \ + \ \ 3 \frac{\partial^2}{\partial r \partial s} \ \ + \ \ 3 \frac{\partial^2}{\partial r \partial s} \ \ + \ \ \frac{\partial^2}{\partial s^2} \ \ + \ \ 3 \frac{\partial^2}{\partial r \partial s} \ \ + \ \ \frac{\partial^2}{\partial s^2}
\ \ \ \ \ \ \ \ = \ \ 18 \frac{\partial^2}{\partial r^2} \ \ + \ \ 12 \frac{\partial^2}{\partial r \partial s} \ \ + \ \ 2 \frac{\partial^2}{\partial s^2}
But now I'm thinking that the
\frac{\partial}{\partial x} (\frac{\partial r}{\partial x}) \frac{\partial}{\partial r} \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \frac{\partial}{\partial x} (\frac{\partial s}{\partial x}) \frac{\partial}{\partial s}
terms should be interpreted as \frac{\partial}{\partial x} operating on \frac{\partial r}{\partial x} and \frac{\partial s}{\partial x} rather than their separate values being multiplied.
Then those terms would vanish and the end result would be
\frac{\partial^2}{\partial x^2} \ \ = \ \ 9 \frac{\partial^2}{\partial r^2} \ \ + \ \ 6 \frac{\partial^2}{\partial r \partial s} \ \ + \ \ \frac{\partial^2}{\partial s^2}
Yeah, you've got it right now. The way I would've done it is really as simple as
\frac{\partial^2}{\partial x^2} = \frac{\partial}{\partial x} \frac{\partial}{\partial x} = \left(3 \frac{\partial}{\partial r} + \frac{\partial}{\partial s} \right)\left(3 \frac{\partial}{\partial r} + \frac{\partial}{\partial s} \right)
Which gets the same result.
  • · Replies 17 ·
