Second Diff Eq question of the day
  • Thread starter Thread starter myusernameis
    Diff eq
The discussion revolves around finding the coefficients p and q in the differential equation y'' + py' + qy = 0, given that y(t) = -te^(3t) is a solution. It emphasizes that the characteristic equation does not need to be solved directly; instead, one can derive p and q by substituting y, y', and y'' into the equation. The calculations show that for the equation to hold for all t, two conditions must be satisfied: -6 - p = 0 and -9 - 3p - q = 0. This leads to the conclusion that p = -6 and q = 9. The discussion highlights the relationship between the form of the solution and the roots of the characteristic equation.
myusernameis
10. If y(t) = -te^(3t) is a solution to y'' + py' + qy = 0, then what are p and q?
so it's equal to r^2 + pr +q = 0, but then how can i find the two numbers?
thanks
You don't need to do any algebra. Remember there are some formulas for solving different equations? This one looks like e^at (At + B) form. Just look over them.
If your solutions were y1 = e^(3t) and y2 = e^(4t), your characteristic equation would be r^2 - 7r + 12 = 0, or (r - 3)(r - 4) = 0, right?
Under what circumstances related to the work above will you get a solution y = te^(3t)?
You don't need to look at the characteristic equation at all. If y= -te^{3t} then y'= -e^{3t}- 3te^{3t}= -(1+ 3t)e^{3t} and y"= -3e^{3t}- 3(1+ 3t)e^{3t}= -(6+ 9t)e^{3t}. Putting those into the equation we have -(6+ 9t)e^{3t}- p(1+ 3t)e^{3t}- qte^{3t}= ((-6- p)+(-9-3p-q)t)e^{3t}= 0 for all t. Since e^{3t} is never 0, we must have (-6- p)+ (-9-3p-q)t= 0 for all t which means we must have -6-p= 0 and -9- 3p- q= 0.
Of course, it is also true that eat will be a solution if and only if a is a root of the characteristic equation and that teat will be a solution if and only if a is a double root of the characteristic equation, which means that the characteristic equation must reduce to (x-a)2= 0.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 35 ·
