Sentences about the Template algorithm
  • Topic:
  • Thread starter Thread starter evinda
    Algorithm
3 replies · 2K views
evinda
MHB
Hello! (Wave)
Could you explain me some sentences,that are related to the following algorithm?
Code:
Template algorithm(G)
   A<-∅
   while A isn't a connected tree
           we define an edge (u,v),that is secure for A
           A<-A U {(u,v)}
   return A
  • Let $G=(V,E)$ be an undirected connected graph with weight function $w:E \to \mathbb{R}$.Let $A \subseteq E$,that is contained in a minimum spanning tree for the graph $G$ and let $(S, V \setminus S)$ any intersection of $G$,that respects $A$.Let,also, $(u,v)$ a light edge,crossing the intersection $(S, V \setminus S)$.Then,the edge $(u,v)$ is secure for $A$.
  • A minimum spanning tree isn't unique.
  • The Template Algorithm is implemented at most $|V|-1$ times.
    Does this sentence maybe stand,because of the fact that $G$ is connected,so $|E|=|V|-1$,and if during the implementation,cycles aren't created,the "while" loop is implemented so many times as the number of edges,so $|V|-1$ times? (Thinking)
  • Let $G_A=(V,A)$.Then, $G_A$ is a forest and each of its connected components , is a tree.
    Why is $G_A$ a forest and not a connected tree,although the condition of the algorithm is:
    Code:
    ? (Thinking)
  • Any secure edge $(u,v)$ for $A$ connects different components of $A$.
Heya! (Blush)
What is that: $(S, V \setminus S)$ any intersection of $G$,that respects $A$? :confused:
If you have edges with equal weight, you may be able to choose which one to include in the mimimum spanning tree.
Not quite. $G$ can have more edges than that.
How many edges can any tree have at most? (Wondering)
That identifies how many times you can add a secure edge.
    Code:
    ? (Thinking)
Let's take a look at the following algorithm:
At which stages is it a forest of trees? (Wondering)
At any time $A$ represents a minimum spanning forest of trees.
If you remove any edge from $A$, it will split one of its trees into 2 sub trees. (Mmm)
The edge $(u,v) \in E$ crosses the intersection $(S, V \setminus S)$, if one of its vertices is in $S$ and the other one in $V \setminus S$.
An intersection $(S, V \setminus S)$ respects a set of edges, if no edge of the set crosses the intersection.
I understand.. (Yes)
$|V|-1$, in order that we don't have cycles.. Or am I wrong? (Thinking)
I like Serena said:
Let's take a look at the following algorithm:At which stages is it a forest of trees? (Wondering)
Nice algorithm! (Mmm) Isn't it a forest of trees at each stage? (Thinking)
I understand! (Nod)
I understand! (Nod)
Yep, yep, and good! (Happy)
