Separable Differential Equation (Perfect Derivative)
13 replies · 5K views
scud0405
[tex]-y + xy' = 0[/tex] and y(2)=5
This first part trips me up. I am supposed to find the perfect derivative, which is [tex](xy') = 0[/tex] ? Is this legal, or does the -y not allow for that?
If that is correct, then I know that I integrate that, which gives me [tex]xy = c[/tex]
Then, to solve for c, I just plug in 2 and 5.
No, it's not exact. And your solution assuming that is wrong. But it is separable. Try that.
It's also linear. Have you studied integrating factors?
Oh, I understand! Just multiply by e^-x, so the problem looks like this:
[tex]-ye^-^x + xe^-^xy' = 0[/tex]
Therefore:
[tex]xe^-^xy = c[/tex]
Correct?
I'm having trouble with the next problem also. The next problem is similar, but with a [tex]x^3[/tex] added to it. I can't think of any other way to do it other than by multiplying everything by e^-x and doing integration by parts to [tex]x^3e^-^x[/tex].Any tips for an easier way to do it?
No, your solution isn't correct. Your original equation
[tex]xy' - y = 0[/tex]
is not in the correct form to find the integrating factor. The coefficient of y' needs to be 1 so you need to divide by x before calculating the integrating factor. Also, as a side note, linear differential equations are typically written with the highest derivatives first much like polynomials, not that it matters that much.
Oh.. you're right.
It's not separable though, is it? When I try and separate it I cannot get the Ys on one side and the Xs on one side. Unless [tex]\frac{dy}{y} = \frac{dx}{x}[/tex] is the equation correctly separated.
remember that is [tex]\frac{1}{x}dx=\frac{1}{y}dy[/tex] You can integrate this.
As for the other method, do you know how to find an integrating factor for second order linear equations? It's generally not just multiply through by [tex]e^{-x}[/tex]
Right. But is that the equation correctly separated?
Yes but I believe the problem is asking you to find an integrating factor.
Okay, so if I divide by X, I get [tex]y' - \frac{y}{x} = 0[/tex]
So the integrating factor would be -x? That can't be right because that just gives me what I started out with.
For y' + P(x)y = Q(x) the integrating factor is
[tex]R(x) = e^{\int P(x) dx}[/tex]
[tex]e^\int^-^1^/^x[/tex] = [tex]e^-^l^n^x[/tex] = -x. So this means I would multiply the whole problem by -x which gives me what I start out with.
Or am I doing something wrong?
Yes you are doing something wrong:
[tex]e^{- \ln(x)} = e^{\ln(x^{-1})}= x^{-1}[/tex]
Ahhh! Finally, it makes sense! Thanks!
