Series Combo Of Capacitors, Smaller Than Single Capacitor
The discussion centers on the validation of the statement that the equivalent capacitance of a series combination of capacitors is always less than the smallest individual capacitor. Participants confirm that the formula for equivalent capacitance in series, given by 1/Ceq = 1/C1 + 1/C2 + 1/C3, supports this claim. The argument is established through algebraic manipulation, demonstrating that Ceq is proportional to the smallest capacitor in the series, thus confirming Ceq < C1 and Ceq < C2. This reasoning can be extended to any number of capacitors in series.
  • Understanding of capacitor basics and capacitance
  • Familiarity with series and parallel circuit configurations
  • Knowledge of algebraic manipulation and equations
  • Ability to apply the formula for equivalent capacitance in series
  • Study the derivation of the equivalent capacitance formula for capacitors in series
  • Explore the implications of capacitor configurations on overall circuit behavior
  • Learn about the effects of voltage distribution across capacitors in series
  • Investigate practical applications of series capacitor combinations in electronic circuits
Students of electrical engineering, electronics enthusiasts, and anyone seeking to understand the principles of capacitor behavior in series circuits.
BOAS
"A series combination of capacitors must always be smaller than the smallest individual capacitor."
This is the statement that I am trying to validate, but I am stuck.
[/B]
I know that if you have a circuit that consists of a cell and a number of capacitors in parallel, the overall effect due to the 'inside' plates neutralising each other, is that of one capacitor with a large plate separation. This large plate separation is what causes the equivalent capacitance to be lower than the sum of it's parts, but I don't understand how I can show that this value must be smaller than that of the smallest capacitor in the circuit.
I can show that it is the case for specific examples, but not a general case.
Thanks for any help you can give,
Jacob.
Perhaps start by showing that 1/Ceq = 1/C1 + 1/C2 + 1/C3 etc
Have you obtained the formula for the equivalent capacitance of two capacitors in series? (You can always deal with more than two by combining two at a time).
Ok,
V = \frac{Q}{C}
So the voltages on the individual capacitors is given by;
V_{1} = \frac{Q}{C_{1}},
V_{2} = \frac{Q}{C_{2}},
V_{3} = \frac{Q}{C_{3}} etc...
The total voltage is V_{tot} = V_{1} + V_{2} + V_{3} + ...
V = \frac{Q}{C_{eq}} = \frac{Q}{C_{1}} + \frac{Q}{C_{2}} + \frac{Q}{C_{3}} + ...
Dividing through by Q yields
\frac{1}{C_{eq}} = \frac{1}{C_{1}} + \frac{1}{C_{2}} + \frac{1}{C_{3}} + ...
Okay, now using what you've done, write and simplify the equation for the equivalent capacitance of just two capacitors in series.
Okay,
C_{1}C_{2} = C_{eq}C_{2} + C_{eq}C_{1}
C_{eq} = \frac{C_{1}C_{2}}{C_{1} + C_{2}}
Excellent. Now does that last expression suggest anything to you about showing that ##C_{eq} < C_1## and ##C_{eq} < C_2##?
Not really...
What if I write the expression this way:
##C_{eq} = C_1 \frac{C_2}{C_2 + C_1}##
Ah ha!
##C_{eq} \propto C_{1}##
##C_{eq} = k C_{1}##
##k = \frac{C_{2}}{C_{2} + C_{1}}##
##C_{2} < C_{2} + C_{1}## (Capacitors can't have negative values)
Therefore ##k < 1##
and
##C_{eq} < C_{1}##
The same argument applies to ##C_{2}##
That makes a lot of sense to me, but is the argument general enough to apply to any number of capacitors?.
See what you can do with what you have now and the comment I made in post #3.
For that, wouldn't it be necessary that C1+C2>1 ?
Ah, I can see where this is going. With three capacitors I can use my previous result to reduce it to an equivalent of two capacitors, and then repeat the argument.
Thanks for the help gneill!
Why? For any positive values of ##C_1## and ##C_2##, can ##C_2## ever be greater than ##C_2 + C_1##?
@siddharth23: In addition to that, how would you compare capacitances to real numbers?
You have a capacitor, C, connected to a voltage source, V. Were you to add a second capacitor in series with C, some voltage will appear across that second capacitor, leaving less than V volts across C. Less voltage on C means there is less charge on C. Less common charge means the circuit's capacitance has been lowered, so must now be less than C.
  • · Replies 18 ·
