Series: converges or diverges help
  • Thread starter Thread starter Slimsta
    Series
The discussion revolves around determining the convergence or divergence of a series involving logarithmic terms, specifically analyzing the behavior of the sequence defined by the terms ln((2n+1)/(3n-1)) as n approaches infinity.
  • Participants explore the behavior of the term (2n+1)/(3n-1) as n increases, questioning its limit and implications for the logarithmic function. There are attempts to identify the common ratio and clarify the nature of the series.
Multiple interpretations of the series' behavior are being explored, with some participants suggesting it diverges based on the limit of the terms, while others challenge the reasoning and clarify misconceptions about convergence criteria.
Participants note that the series is not geometric in nature and discuss the implications of terms not approaching zero for convergence. There are also references to the limitations of using the limit of terms to conclude about series behavior.
Slimsta
Determine whether the series [PLAIN]http://img265.imageshack.us/img265/69/44751948.jpg converges or diverges and find its sum S if it does converge.
my textbook has lots of weird examples but none of them help me understand how to solve this one..
if i plug in 1 then 2 then 3... i get
ln(1.5) + ln(1) + ln (7/8) +...+ln((2n+1)/(3n-1))
so a = ln(1.5)
r = ?
then i use the formula: a / (a-r)
right? now how do i find r?
so a = ln(1.5)
r = ?
What can you say about [itex]\frac{2n+1}{3n-1}[/itex] as [itex]n\to\infty[/itex]? And then about [itex]\ln\left(\frac{2n+1}{3n-1}\right)[/itex]? Now considering adding a bunch of terms that eventually behave like [itex]\ln\left(\frac{2n+1}{3n-1}\right)[/itex]
worth checking what the nth term does for large n
[itex]\frac{2n+1}{3n-1}[/itex] as [itex]n\to\infty[/itex] will be 0
and for [itex]\ln\left(\frac{2n+1}{3n-1}\right)[/itex] it will be ln(0) which is impossible..
but if plugging numbers like 10, 100, 1000... into [itex]\ln\left(\frac{2n+1}{3n-1}\right)[/itex] the number becomes smaller and smaller all the way to -[itex]\infty[/itex]
so does it mean that the answer is 'Diverges'?
As n goes to infinity, [itex]\frac{2n+1}{3n-1}[/itex] does not go to zero.
oh my bad.. its 1
ln(1) = 0
so the answer is Diverges, S=0. ?
Slimsta said:
oh my bad.. its 1
ln(1) = 0
Wow! Two mistakes in only three lines!
(2n + 1)/(3n - 1) doesn't approach 1, so ln( (2n + 1)/(3n - 1)) doesn't approach 0.
Furthermore, in a series [itex]\sum a_n[/itex], if lim an = 0, you can't conclude much of anything. Consider [itex]\sum 1/n[/itex] and [itex]\sum 1/n^2[/itex]. In both series an --> 0, but the first series diverges and the second series converges.
Sorry. This is incorrect.
I can not speak too much about series convergence/divergence, but I can talk about a sequence:
What happens to [tex]\frac{2n+1}{3n-1}[/tex] as n ---> infinity?
You can rig this so that the 1's cancel and you are then left with [tex]\frac{2n}{3n}[/tex] which obviously then cancels down to [tex]\frac{2}{3}[/tex] (i.e. the limit of the sequence).
Now as you are actually dealing with a natural log, the limit of the sequence in actual fact is [tex]ln(\frac{2}{3})[/tex]
If you wished to prove this you could do the following for all n > N: [tex]|ln (\frac{2n+1}{3n-1}) - ln(\frac{2}{3})|<\epsilon[/tex] Also, note that this sum is not a geometric progression: you find r as such: [tex]r = \frac{t_{n}}{t_{n-1}}[/tex] where [tex]t_{n}[/tex] is the nth term of the series. Take note of the second term of the sequence, it equals zero, and division by zero is undefined. Also, r is the common ratio. So the series is, by definition, not geometric in nature.
I am not absolutely sure of this, but I believe the series in fact diverges to negative infinity, because of the simplification of the natural log as per above. You have an infinite number of ln(2/3) to multiply out which is equal (in a very loose sense) to negative infinity. I may be wrong however.
Slimsta said:
oh my bad.. its 1
ln(1) = 0
The series diverges, but not due the reasons you pointed out (which were not only incorrect).
Think about what happens if the n-th term in your sum does not tend to 0. Why does the following series diverge?
[tex]\sum_{n=1}^\infty k = k + k + k + k + k + \dotsm[/tex]
where [itex]k\not=0[/itex]. Think about how this relates to the series in the original problem.
  • · Replies 22 ·
