Series or Parallel: Connecting 6 Light Bulbs to a Hanging Lamp
  • Thread starter Thread starter dmolson
    Parallel Series
The discussion centers on the connection of six 120V light bulbs in a hanging lamp, with a consensus that they should be wired in parallel. This configuration ensures that each bulb receives the full voltage from the source, allowing for consistent brightness and independent operation. Connecting bulbs in series would divide the voltage among them, leading to dimmer lights and a complete failure if one bulb burns out. The traditional wiring method for household lighting is therefore parallel to maintain optimal performance.
  • Understanding of electrical circuits
  • Knowledge of voltage and current concepts
  • Familiarity with series and parallel circuit configurations
  • Basic electrical safety practices
  • Research the principles of electrical circuit design
  • Learn about the advantages of parallel circuits in household wiring
  • Study the effects of load on voltage and current in series vs. parallel connections
  • Explore troubleshooting techniques for electrical circuits
This discussion is beneficial for electricians, electrical engineering students, and anyone involved in home wiring or lighting design who seeks to understand the implications of circuit configurations on performance and safety.
dmolson
I know that this is going to sound like a stupid question, but I was wondering if someone could explain the reasoning behind this question.
A hanging lamp illuminates a banquet table using 6 light bulbs (120 V). How are the bulbs connected? Series or parallel?
Any help would be great.
I think that it would be parallel so that each light receives the same amount of current, but I am not really sure.
If they are in series that well each receive the same amount of current since they the current will pass through only one path, that includes all of the bulbs. However, in parallel, each bulb will have the full voltage from the source applied to it.
Thread moved to Homework Help forums. Please do not post homework or coursework in the general forums.
The traditional way that 120V light bulbs are wired is in parallel. Quiz question for the original poster (the OP, dmolson) -- why would you not want to connect all the light bulbs in your house in series?
A key factor in a series connection would have to do with a certain additive property of each load on the system.
Dmolson, normally any combination of lambs would be connected in parallel, there are two reasons for this:
first, the outlet of your home gives a constant 120V with varying current (depending on the load), so when you connect several lambs in parallel, you will have a constant voltage drop on all of them and they can take as much current as they want (there is a limit!), while if you connected them in series, the voltage across the lambs will be divided among them, while having constant current which is not what we wnat, the second reason is that if you connect lambs in series, if one of them goes out, the one's following this lamb will go out too.
Electrified lambs are not, to the best of my knowledge, either tasty OR safely cooked... And it's kind of cruel and unusual to the lamb, isn't it! :biggrin:
16K
  • · Replies 22 ·
  • · Replies 19 ·
