Session timeouts when posting long answers
  • Thread starter Thread starter JM
15 replies · 4K views
JM
I really need help with posting. When writing a long answer to a post the systems times me out and makes me log in again. sometimes it keeps what I had written and enters it, but just now it erased all of what I had painstakingly created and I need to start all over again. Isnt there some way to transfer something I can write on my word processor, where there is no time limit, to the message box without having to completely re write it?
JM
Whenever you log in, make sure you check the box "Remember Me". This way you won't get logged out.
Thanks, micromass, I'll try it.
Simply copy and paste. I sometimes do this with long posts, but I use a plain text editor: TextEdit on Mac OS. Notepad or something similar for Windows will do the job just fine.
Also getting back in your browser history can help - most modern browsers remember content of the edit field before submitting it to the site. So after you are logged out and asked to log again - do it, then after being shown an empty edit filed go back in the history till you see the same edit field - but containing your post. Submitting it at this moment should work, as "logged in" cookie is already present.
Thanks for all the ideas.
Now two more things: 1. how do I show a squared symbol without the sup tags showing?22 2. How do I work the multi-qoute so my answer appears in a clear space instead of the shaded space wherre the quote is?
JM
[noparse]102[/noparse] -> 102
[noparse]
This is a quote.
[/noparse] ->
This is a quote.
And text here is not a quote.
->so now is it clear.
[noparse][/noparse] ->
-> 102->
Just practicing to see if I got it.
JM
Borak- Nope I don't got it. Do I add the -> after the sup2sup so the sups don't appear in the posted reply?
What I'm trying to do is to add my comments in a clear area between the sections of quoted material. I don't see how to do it.
JM
His -> is simply a shorthand for "gives you". If you enter the code that he showed before the ->, you should see what he showed after the ->, when the posted message appears on the screen.
When you hit the "quote" button, you get a message-composition window with the quoted message pasted in, with a [noparse]
[/noparse] tag before it and a [noparse]
[/noparse] tag after it. To split it into two quotes and insert your own comments in between:
1. Click at the point where you want to split.
2. Type in a [noparse][/quote][/noparse] tag to end the first section, which starts at the original [noparse]
[/noparse] tag.
3. Type in your comments.
4. Type in a [noparse]
[/noparse] tag to begin the second section, which ends at the original [noparse]
[/noparse] tag.
Edit by Borek: Following comment is no longer true - there are [nоparse][/nоparse] tags that can be used to format posts in such situations. Above part of the post corrected.
Very important note: actual "unquote" tags have a forward slash "/" in them, not a backward slash "\". I had to use backward slashes in my instructions so that the forum software wouldn't interpret them as real quote tags and make hash out of my post. So when you do it, replace my backward slashes with forward slashes.
103
When you hit the "quote" button, you get a message-composition window with the quoted message pasted in, with a [noparse][/noparse] tag after it. To split it into two quotes and insert your own comments in between:
[/noparse] tag.
I had been using the icons, but now I think to type the breaks myself. Is it working?
4. Type in a [noparse][/noparse] tag.
JM said:
103
No, you're forgetting the / in the last . You should type
Code:
[noparse]10[SUP]2[/SUP][/noparse]
Click on the x2 above your posting window to see what you should do.
OK the quote part works. But I used uc, let's try lc.
104
104
Does it have to be italic?
105
Micromass. Thanks I think I got it now.
JM
Aha, thank you! I wasn't aware of that, and was wondering how you managed to get the tags to show in your post. :biggrin:
