Undergrad Can sets contain coordinates of points and be used in Cartesian product?
A set can indeed contain coordinates of points, such as A = {[1,3]; [4,5]} and B = {[7,8]; [4,2]}. The Cartesian product of these sets is correctly represented as A × B = {[1,3][7,8]; [1,3][4,2]; [4,5][7,8]; [4,5][4,2]}. It is recommended to use round parentheses for tuples and commas for separation, resulting in A = {(1,3), (4,5)} and B = {(7,8), (4,2)}. The Cartesian product can also be defined in terms of functions, illustrating its broader mathematical applications. Understanding these concepts is essential for clarity in set theory and related fields.
control
Hi guys,
I would like to ask if a set can contain coordinates of points, for example A={[1,3];[4,5];[4,7]} and if we can do Cartesian product of such sets, for example A={[1,3];[4,5]}, B={[7,8];[4,2]} A×B={[1,3][7,8];[1,3][4,2];[4,5][7,8];[4,5][4,2]} (is it correct to write it like that?). I am familiar with doing that when we have sets of numbers (A={1;2}, B={7;5} A×B={[1,7];[1,5];[2,7];[2,5]}). but I am not sure if it is correct with coordinates of points.
Mod note: Fixed typo "carthesian"
Mathematics news on Phys.org
control said:
Hi guys,
I would like to ask if a set can contain coordinates of points, for example A={[1,3];[4,5];[4,7]} and if we can do carthesian product of such sets, for example A={[1,3];[4,5]}, B={[7,8];[4,2]} A×B={[1,3][7,8];[1,3][4,2];[4,5][7,8];[4,5][4,2]} (is it correct to write it like that?).
You can write the elements whichever you want, e.g. ##[1,3][7,8]## or ##[1,3;7,8]## or ##[1,3,7,8]## or ##\begin{bmatrix}1&3\\7&8\end{bmatrix}##. It is certainly useful not to mix them like ##[1,7][3,8]##, because this would probably be harder to read, but as long as you're consistent, there is no rule.
I would probably write ##A=\{(1,3),(4,5)\}\; , \;B=\{(7,8),(4,2)\}## as round parenthesis are more common for tuples and commas as separators in a list, and then ##A \times B = \{\; ((1,3),(7,8))\, , \, ((1,3),(4,2))\; , \;((4,5),(4,2))\, , \,((4,5),(4,2))\;\} ## but only in set theory. With different applications, this might change.
Thanks for answer.
Perhaps the definition of the Cartesian product would be of some use. Let ##\Gamma## be be an arbitrary nonvoid set, and a set ##A_\gamma## is putted in correspondence to each element ##\gamma\in\Gamma##. Then by definition a set ##\Pi_{\gamma\in \Gamma}A_\gamma## consists of functions ##f:\Gamma\to \bigcup_{\gamma\in \Gamma}A_{\gamma}## such that ##f(\gamma)\in A_\gamma##.
For example a set ##\mathbb{R}\times\mathbb{N}## consists of functions ##f:\{1,2\}\to \mathbb{R}\cup\mathbb{N}## (it looks little bit strange, obviously ##\mathbb{R}\cup\mathbb{N}=\mathbb{R}##) such that ##f(1)=a_1\in\mathbb{R},\quad f(2)=a_2\in\mathbb{N}##. This function is also presented as ##(a_1,a_2)##.
Another example: a set ##\mathbb{R}^\mathbb{N}## consists of all functions ##f:\mathbb{N}\to\mathbb{R}## those functions can be presented as infinite sequences ##(a_1,a_2,\ldots),\quad f(i)=a_i\in\mathbb{R}##.
If all the ##A_\gamma## are vector spaces over the same field then ##\Pi_{\gamma\in \Gamma}A_\gamma## is also a vector space. By the Choice axiom the set ##\Pi_{\gamma\in \Gamma}A_\gamma## is not empty as long as all the sets ##A_\gamma## are not empty
You forgot to mention that the Cartesian product solves a universal mapping problem.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
