Shankar - Simultaneous Diagonalisation of Hermitian Matrices
bugatti79
Asked to determine the eigenvalues and eigenvectors common to both of these matrices of
[tex]\Omega=\begin{bmatrix}1 &0 &1 \\ 0& 0 &0 \\ 1& 0 & 1\end{bmatrix}[/tex] and [tex]\Lambda=\begin{bmatrix}2 &1 &1 \\ 1& 0 &-1 \\ 1& -1 & 2\end{bmatrix}[/tex]
and then to verify under a unitary transformation that both can be simultaneously diagonalised. Since Omega is degenerate and Lambda is not, you must be prudent in deciding which matrix dictates the choice of basis.
1)What does he mean by being prudent in the choice of matrix?
2)There is only one common eigenvalue which is [tex]\lambda=2[/tex] I expect the same eigenvector for both matrices for this value of [tex]\lambda=2[/tex]? Wolfram alpha shows different eigenvectors for the same [tex]\lambda[/tex] value.
eigenvector '{'1,0,1'}','{'0,0,0'}','{'1,0,1'}' - Wolfram|Alpha
eigenvector '{'2,1,1'}','{'1,0,-1'}','{'1,-1,2'}' - Wolfram|Alpha3) To show Simultaneous Diagonalisation I applied the unitary transformation as
[tex]U^{\dagger} \Omega U[/tex] and [tex]U^{\dagger} \Lambda U[/tex] to diagonalise the matrices with its entries being the eigenvalues where [tex]U[/tex] are the corresponding columns of eigenvectors.
However, wolfram shows
'{''{'1, 0, 1'}', '{'-1, 0, 1'}', '{'0, 1, 0'}''}''*''{''{'1,0,1'}','{'0,0,0'}','{'1,0,1'}''}''*''{''{'1,-1,0'}','{'0,0,1'}','{'1,1,0'}''}' - Wolfram|Alpha
'{''{'1, 0, 1'}', '{'-1, -1, 1'}', '{'-1, 2, 1'}''}''*''{''{'2,1,1'}','{'1,0,-1'}','{'1,-1,2'}''}''*''{''{'1, -1, -1'}', '{'0, -1, 2'}', '{'1, 1, 1'}''}' - Wolfram|Alpha
Any ideas?
Couple of comments:
1. Pick the non-degenerate matrix to get your eigenvectors. You're not guaranteed that the degenerate matrix's eigenvectors will span the space and be a basis.
2. You need the transformation to be unitary, which means the eigenvectors need to be orthonormal. Use Gram-Schmidt to orthonormalize the eigenbasis.
Ackbach said:
Couple of comments:
2) I thought that hermitian matrices were orthgonal as per the 4th point of properties in link wiki https://en.wikipedia.org/wiki/Hermitian_matrix
Thats why i didn't orthogonalise them...
Eigenvectors of Hermitian Matrix
eigenvectors '{''{'2,1,1'}','{'1,0,-1'}','{'1,-1,2'}''}' - Wolfram|Alpha
Check are eigenvectors orthogonal ( I put the eigenvectors into a matrix)
'{''{'1, 0, 1'}', '{'-1, -1, 1'}', '{'-1, 2, 1'}''}' orthogonal - Wolfram|Alpha
Is the wiki wrong?
Is the wiki wrong?
Ok, fair point about orthogonality. However, orthogonal does not imply orthonormal. An orthonormal basis is orthogonal AND every vector has length 1. You need an orthonormal set of eigenvectors to form an orthogonal matrix. That's not a typo: orthogonal matrix implies the columns are orthonormal.
So your process is simpler if your original matrices are Hermitian: once you get the eigenvectors, just normalize them.
