Share and discuss your astrophotography
315 replies · 226K views · last reply
March 3rd lunar eclipse
  • Photo of a totally eclipsed Moon glowing reddish-orange against a black night sky, with a few faint stars scattered around it.
russ_watters said:
New Saturn from last Friday attached. Only marginally better quality, but it is twice the magnification (Barlow lens). That's about the magnification limit (400x or so) and light gathering limit of my scope with my quickcam. Sky's could be better though (over Xmas, I'll drive up to the Poconos...). The image was dim enough its starting to look grainy. I'm working on a long-exposure mod for the quickcam. You can't see anything at all deep-sky with it at 1/5 second exposures.
HEY NEED HELP
i am and first timer in all this but i have purchased a konus 70 telescope it has a focal lengh of 900mm aperture of 70mm
can somebody tell me how i view planets with this what lenses do i use to give me a good view of the planet like saturn and Jupiter help please
Saturn is up right now, Jupiter is not (until early morning). Start with your largest eyepiece (I'd guess they gave you a 15mm or so), then put a barlow lens on it after you get the planet centered.
What if you just have 1 and half of an eye? Any suggestions there?
hey i didnt gt a barlow with mine but how much magnification is required to see Jupiter like in ur pics a 900mm focal divided my a 10mm eye peiece shoudl give me 100* mag
I didn't use a telescope. I used a 300mm lens on my camera.
There are some pictures of lightning that I took the other night.
In my Blog
They are not astro photos but I figured you would like to see them anyway.
Hello
Hi Guys, I am new here and there appears to be some really great stuff going on.
Ive been into astronomy for a few years and I am recently beginning to take it more seriously. I've got a Celestron 675 Telescope and I am looking to upgrade it soon.
Im also an amateur photographer and want to extend my skills into the world of astrophotography and this looks like a great place to start.
So to start I thought I would attach a couple of photos. One from the recent lunar ecplise and one from my second attempt at astrophotography. The first is a series of 4 images of the various stages of the eclipse. The second is a 27 image stack looking towards Orion.
  • Composite of four images of the Moon during a lunar eclipse, progressing from full bright moon at lower left to a dark reddish eclipsed Moon at upper right.
  • Night sky photo with scattered stars and a blurred tree silhouette at the bottom; a sparse star pattern in the centre, consistent with the Orion region.
I've made a lot of recent updates to my website. Here's something that took me forever to take. It is 8.5 hours of exposure (at f 7.5), taken over about two weeks. I think, Astronuc, that you are right about my skies being a severe limiting factor. At 8.5 hours, even at f7.5, I should have a whole lot better s/n ratio. Still, not too bad...
  • Astrophotograph of the M101 Pinwheel Galaxy, a face-on spiral galaxy with bright blue-white spiral arms around a glowing central core, set against a dark star field. Caption reads: M101 - Pinwheel Galaxy, Dist: 27MLY, Dia: 170KLY, May, 2007, ED 80, DSI II Pro, 30x9 L, 10x6m R, 10x9m G,B.
This one's better. It doesn't have the dim outer arms of a spiral galaxy, so it doesn't need quite so much s/n ratio.
  • Astrophotograph of the Black Eye Galaxy M64: a tilted oval galaxy with a bright central nucleus and dark dust band, set against a black starfield. Caption reads M64 - The Black Eye Galaxy, Dist: 19 MLY Dia: 80,000 LY, 60x2min L, 25x2,3,3min RGB.
I took this one with a borrowed Galileo Reflector, D:114 F:7.9 , 20mm eyepiece
I just placed a Sony DSC H5 on the eyepiece.
I am going to an astronomy club and i am considering to build a 150mm reflector to use for astrophotography.
I was also looking for an ecuatorial mount, the EQ4, i eard it can be motorized, i can get one for $300 without motors, what do you recomend??
  • Photo of a waxing gibbous Moon, lit from the right, showing dense craters along the terminator and dark maria across the lunar surface.
Here's some beginner astrophotography: Crux and Alpha and Beta Centauri. This is the first time I have actually "processed" an image (followed a set of cookbook instructions to remove LP, online). Didn't bother to remove the noise. I think the unprocessed one shows more stars. :biggrin:
http://farm2.static.flickr.com/1098/525227250_27cdce84c2_b.jpg
It's still a nice pic, indeed. I have one question regarding combining the separate exposures: did you have to re-align them, or were they all in the correct orientation already (requiring just a translation to match up)? I'm asking this in relation to fixing relative rotations between the different exposures: rotating them to mach orientations would inevitably mean that you lose some detail.
I have a Celestron C4.5 reflector telescope, and a Minolta XR-5 (I think) camera. I got the parts to connect the two, but found that I couldn't get it to focus. To make the connection, first the lens assembly must be removed from the camera. How can it be focused once it's on the telescope?
Some Newtonians don't have enough in-focus travel to focus some cameras. You can try modifying the focuser assembly (ie, getting a shorter one) or using a focal reducer or barlow to alter the focal length.
Has anyone here tried the new version of Google Earth with Google Sky, just wondering what you though of it.
One very interesting thing about it is you can create and share your own imagery.
Need help about digital cameras
Dear Astrophotographer-Forumers!
A would like to get some help from You! I need a digital camera for my work that has the following capabilities:
- Minimum 1fps image capturing rate
- ...at 2MP size at least.
- and all these thing WITHOUT any external control (I mean PC-conrtol, or something else. Just the camera on its own.)
- and this should work for at least 2 hours.
Do you know any type of camera that can match these things?
I hope you can help!
Thank so much in advance!
Kind regards,
T. the M.
I'm not sure such a thing is possible - the problem is memory. Shooting 1sec, 2mp exposures for 2 hours will require 30 gigs of it. You may be able to do it with a hard drive equipped digital video camera, but I'm not sure if they are that programmable.
Dear Russ_Waters,
Yes, I considered this problem, but I can imagine, that it is possible to change the memory card (SD, for example) when it is needed. The camera signs with a beep, or something. . .
Of course I can make a compromise, if there is something that can do it at a lower fps.
Many thanks,
Telmerk
I don't have to much experience in astrophotography, but here are two pictures i would like to show you:
1. Comet 17P Holmes (1. Nov., 23:00 GMT), stack of 60 Photos with 30 seconds exposure, f=200mm SLR objective mounted on a FLI Maxcam CM7 CCD camera. The "spiral" was probably caused by a hot pixel or dark current. 30 dark frames combined and subtracted from the image. I would have wished to be able to take photos with the telescope, but the guiding turned out to be too inaccurate...
2. Moon mosaic. Same ccd camera as for the comet. Telescope: 5" Mak-Cass
(! Filesize !) http://www.astrospectroscopy.com/unterseiten/bilder/mondmosaik.jpg"
I hope you can understand my poor English :frown:
Yannick
  • Long-exposure astrophotograph of comet 17P/Holmes as a bright diffuse glow with a small bright nucleus, surrounded by scattered stars on a black background.
Yannick, I agree with Russ (at least on this non-political issue):smile: That is a wonderful image! Here is a site that is inhabited by some of the best amateur astrophotographers in the world (not an overstatement!), and you should start posting your stuff there.
http://forum.ourdarkskies.com/
One of our members (Noel Carboni of Florida) is a post-processing genius and he and his astophotographer partner Greg (in England) have produced some of the most amazing images you've ever seen. They have a book in the works that will be a best-seller amongst astronomers (and not necessarily just amateurs). Once you are a member of ODS, Noel will give you (FREE, yes, really FREE) a set of his actions for Photoshop that will help you get the most out of your images. The web-master, Vincent, is a good guy and fun to deal with, too. Come on over. Neutrino (a member here) invited me to go there a year or two ago, and I appreciate that heads-up!
