Shielded and unshielded dose from a Co-60 source are the same?
  • Thread starter Thread starter Joao Pedro
    Mcnp6
The forum discussion centers on the design of a shield for a Co-60 source using ambient dose equivalent tally 5. The user initially calculated a required lead shield thickness of approximately 9.5 cm to reduce the dose to 1 mSv/year. However, upon verification with MCNP, the user observed that the output dose was nearly identical to the unshielded scenario, indicating potential errors in the input file. Guidance was provided to check geometry using the MCNP options and correct specific cell definitions to resolve the discrepancies.
  • Understanding of radiation shielding principles
  • Familiarity with MCNP (Monte Carlo N-Particle Transport Code) version 6 or later
  • Knowledge of ambient dose equivalent and its calculation methods
  • Basic skills in geometry definition and manipulation within MCNP
  • Review MCNP geometry plotting options, specifically using the 'ip' command
  • Study the principles of radiation shielding calculations and their applications
  • Learn about the correct definitions of cells and surfaces in MCNP
  • Explore troubleshooting techniques for common MCNP input file errors
Radiation safety engineers, medical physicists, and anyone involved in radiation shielding design and verification using MCNP.
Joao Pedro
TL;DR
Ambient dose equivalent from a Co-60 source shielded and unshielded dose are basically the same
I was tasked with designing a shield for a Co-60 source, I decided to use ambient dose equivalent, tally 5. I got my results, followed "Radiation Problems: From Analytical to Monte-Carlo Solutions" example and arrived at a dose of X. I performed some shielding equations and arrived on a required shield of ~9.5 cm of lead to bring the dose down to 1 mSv/year, but when I went to double check my answer performing a MCNP test I am getting basically the same pSv/gamma from the tally 5 output as my unshielded input file, am I doing something wrong here? Was my initial input incorrect? (the input file is a bit disorganized since I was tinkering if it)
I couldn't attach files when making the tread.
Hello @Joao Pedro,
Welcome to PhysicsForums. If you run mcnp with options ip it will plot the geometry. Dotted lines tend to indicate geometry errors.
As a shorthand for reading geometry +surface is usually above or outside, -surface is usually below or inside. You've added two nested boxes 20 and 21, cell 16 then needs to have that volume removed. I think you've tried to do that and called it cell 19, but the definition includes -20 21. Box 20 is inside box 21, so the volume inside 20 but outside 21 doesn't make sense. Likewise for cell 17 being +8 -20. That is the volume inside 20 but outside the whole experiment. I think you mean +5. So I've changed 3 lines, two fixed and one commented out.
Code:
c 16  2 -0.000124      5 6 7 -8  IMP:N=0 IMP:P=1 $ See if material for cell 15 and 16 are correct
17  304   -0.128     5 -20     IMP:N=0 IMP:P=1
19  304 -0.000124    -8 7 6 5 21       IMP:N=0 IMP:P=1
See if this solves the problem.
  • · Replies 24 ·
  • · Replies 20 ·
20K
