Shining a light beam back -- relativity
  • Context: Undergrad
  • Thread starter Thread starter Invutil
    Beam Light Relativity
The discussion revolves around the implications of relativity on the perception of light speed and time dilation between observers in relative motion. Participants explore concepts such as the speed of light, time dilation, and the twin paradox, while questioning the nature of motion and rest frames in relativistic contexts.
  • Some participants assert that all observers see light traveling at speed c, regardless of their relative motion.
  • There is a discussion about whether time dilation or length contraction is responsible for the perception of light speed, with some questioning the geometry of spacetime.
  • One participant mentions that filming each other would lead to observing time dilation, but cautions about the effects of light travel time and changing distances.
  • Another participant clarifies that the Doppler effect influences the perceived rate of clocks when observing moving objects.
  • Some participants discuss the twin paradox, noting the asymmetry between observers in different frames of motion, particularly in scenarios involving acceleration.
  • There are inquiries about the role of direction and velocity in the perception of light speed and time, with some proposing complex scenarios involving relative motion.
  • One participant suggests that the results of interferometer experiments could be explained by assuming the emitter's inertia affects light, raising questions about the nature of light's propagation.
  • Another participant emphasizes that the state of motion of the source affects the energy and direction of light but not its speed.
Participants express multiple competing views regarding the nature of time dilation, the effects of motion on light perception, and the implications of the twin paradox. The discussion remains unresolved with no consensus on several key points.
Participants highlight limitations in understanding rest frames, the effects of acceleration, and the assumptions underlying various experiments. There is ongoing uncertainty regarding the implications of different models and interpretations of relativity.
Invutil
According to the textbook, "In this case, you (A) and Jackie (B) no longer agree about her speed _relative_ to the speed of the light beam. She'll see the light beam pass by her at the speed of light, c, but you'll see it going only 0.1c faster than she is going."
Illustration here, under "The Speed of Light" heading: http://cse.ssl.berkeley.edu/bmendez/ay10/2002/notes/lec11.html
My question is, does her rate of time slow down or her length increase, so that to her it appears that the light traveled a full 1c instead of 0.1c in a second?
And what if she shines a light back?
Exactly as the quote says: "She'll see the light beam pass by her at the speed of light, c ...". All observers see light traveling at c.
I get that works from the general idea of interferometer experiments, which by 1947 showed to an error of +-4 km (within the bounds of Earth's rotation speed around the sun at 30 km/s) that light speed is unaffected by direction or motion, and from the airplane cesium clock experiments. But if each filmed the other person, each would see the other's time slowed down right? So it is like there is a time warp between them? My other question: we can't assume the airplane has a single rest frame throughout the flight, so we know it is absolutely moving and is the time dilated side? It seems like quantum theory to say that each side is correct in having a rest frame and all the possibilities happen at the same time.
There is no such thing as absolute motion. Not in relativity nor in classical mechanics.
It is not a matter of time slowing or lengths increasing, it is a matter of the geometry of space-time as a whole.
Beware here. When you say "filmed" you would also need to take into account that light does not arrive instantly and that the distance between them changes. Relativistic effects such as time dilation and length contraction are what remains after you account for this.
If you film someone the Doppler effect will mean that their clocks will appear faster as they approach and slower as they recede. If you subtract out the light travel time, you will calculate that their clocks tick slowly, yes.
There's no time warping going on. It's easiest if you think of spacetime as a four-dimensional entity. The path you follow through spacetime is called a worldline, and different paths have different lengths - but the "length" of a worldline turns out to be the elapsed time on that route. Then the Hafele-Keating experiment to which you refer is not very different from noting that not all routes from London to Edinburgh are the same length.
There's an Insight on this forum by Orodruin on the geometric view of the twin paradox - I'd take a look at that.
That's very observant. You noticed something of importance. An observer who remains at the airport is fundamentally different from an observer who flies around the world inside the airplane. The observers' roles are not symmetrical. Situations where both observers move relative to each other in a straight line at a steady speed are fundamentally different because there the observers' roles are symmetrical.
A situation like the one with the airplane comes up so often that it's famous. It's called the twin paradox. It's a comparison of two proper times, as opposed to the other situation mentioned above, which is always a comparison of a proper time to a dilated time.
Invutil said:
we can't assume the airplane has a single rest frame throughout the flight ...
Of course we can because it does. In YOUR rest frame, you are never moving. What you are getting at, I think, is that the airplane in not in uniform inertial motion throughout the flight because it undergoes acceleration at the takeoff and landing. Another way of saying that would be that the airplane does not have an inertial rest frame throughout the flight, but note the adjective "inertial" in front of rest frame.
Or to be precise, the frame in which the airplane is at rest throughout the flight is not an inertial frame.
Yes, better. Thanks.
Does the direction/vector of velocity matter?
If the other side is moving closer, into the shining light, it would seem they are traveling by 1c + 0.9c or (1c + 0.9c)/(1 + 0.9c * 1c / c^2) = 1c, so their perceived time rate looking at the outside world would have to increase so the light seems to go slower in their seconds.
And if we use the train example, which calculates time dilation, it would seem they have to be slower on the train in all cases.
We can draw a slightly complicated triangle if the direction of light is not perpindicular to velocity.
Does absolute space and velocity work then?
Also, the equation (ct')2 + (vt)2 = (ct)2 seems to say "Lose some time by gaining some position offset". Is it right then that, if you gain time, it is everything else moving relative to you?
And, in the train example, velocity is inward to B, but A's time goes slower, while its effect according to Doppler should be an increased frequency.
They will always observe their own time passing just as it would if they weren't travelling.
However, when the time that passes for the traveler is compared to the time that passes for a non-traveler there's a discrepancy.
Couldn't all of the interferometer experiments results be explained if we assumed the emitter inertia passed on to the lightwave/photons and so we would not see any sideways fringe or forward change in the speed of light? And is Doppler shift from the stars not exactly the speed of light affected by inertia of emitter? Assuming the time for the first crest to cross the distance and the speed of the crests is the same thing. Sound has an aether (air) but light doesn't, so there shouldn't be any speed limit / barrier.
If at any time our absolute acceleration at any point through space is >0.0000001c, this would seem to matter though.
You can see that the speed of light is source independent because you would expect binary stars to appear to have uneven orbits otherwise. Light from the bit of the orbit coming towards us would get here early while light from the bit going away would be late. We don't see this.
The state of motion of the source affects the energy and direction of the light. Just not its speed.
c is a measure of speed, not acceleration
If light is emitted with its own speed, like sound waves, it seems like light is then in an aether that is at rest with relation to the local universe. Now I think I have to dig around in the Michelson-Morley and de Sitter experiments.
I was considering measuring the speed of light as it travels along a path length of 1 km, which should cause a 3x10^-8 m offset as the Earth is accelerated 3 mm/s^2 off by the Sun.
Except that the speed of light is the same regardless of the velocity of the observer. This is unlike a sound wave, where the measured wave velocity does depend on the velocity of the observer relative to the medium. Measuring the speed of light is a trivial exercise nowadays and experiments have consistently shown the velocity to be c regardless of the motion of the emitter or observer.
Also, there is no rest frame for the local universe. Any arbitrary frame is perfectly acceptable (though we commonly use a frame at rest with respect to the CMB simply for convenience).
I've shown the contradictions in that kind of reasoning above. And it seems there is some uncertainty about the de Sitter binary star experiment.
I'm sorry I don't see where you've shown any contradictions.
Well, there is. Sorry.
Yes. But then you'd have light traveling at different speeds in a vacuum. Other measurements show that light doesn't do that!
Tell that to the scientists, technicians, and engineers who accelerate particles for a living. Why would it take ten times as much energy to go from rest to a speed of ##0.9999 c## as it does to go from rest to a speed ##0.99c##? You've got 90% of the energy being expended to raise the speed that last 1%. And if you try to go faster that problem gets worse. You expend 100 times more energy and you get a further speed increase of one-millionth of 1%.
The way anyone (not just you) thinks things "should" be has no bearing on how they actually are.
The points in the post Shining light beam back -- relativity still can't be answered. It seems there should be a slowdown of time at all levels of physics for objects moving in a certain direction so that if it is compared to light, it will always be c. This would lead to weird chemistry though. I don't know the answer but it seems relativity is incomplete.
Huh? Time locally always runs at one second per second. Are you saying otherwise?
There is time dilation so time runs slower for somebody. But to them it will appear others are faster, or else you make it really absurd and say "everything is possible, ooh, quantum observers," (many world's interpretation) and it seems to me it is that direction of thought that has been over-extrapolated. You can always film others and if they see themselves they must admit that their relativity was violated, or else it resolves. I think that relativity just hasn't been thought through to the end.
I have no idea what you are talking about. None of that seems to make any sense.
Let's go back to my question, which you did not answer:
I can't quite follow what's going on in your pictures (they are a little messy and disorganized and I don't usually do relativity equations), but the basic questions you raised about whether the direction of the velocity matters and how time passes for different observers has been answered for 100 years. There are few known inconsistencies, if any.
It is not. Not in the sense that you or I (not being experts in relativity) would understand. Whatever incompleteness you think you've found I can assure you it is not true.
Time dilation due to relative motion is a two-way street. Both observers will see the other's time as passing slower than their own.
We've done these experiments. They fully support relativity.
The Lorentz transform is isotropic, meaning that it is the same in all directions.
The Lorentz transform includes more than just time dilation. It also includes length contraction and the relativity of simultaneity. With all of those taken together the light does not go slower in their seconds.
The only kind of absolute space which works is one which hides itself so that it is completely undetectable by any means. Most scientists feel dissatisfied with a conspiracy theory as the core of a physics theory.
The Lorentz transform is the same in any frame. Relative to any inertial frame, moving clocks always run slow.
Time dilation is different from Doppler shift. Both can be derived from the Lorentz transform, but they are different. For one, time dilation is isotropic, but Doppler shift is not.
Invutil said:
The points in the post Shining light beam back -- relativity still can't be answered ... it seems relativity is incomplete.
Well, your understanding seems incomplete, but that isn't the same thing. Why don't you wait to learn a bit more before rushing to a hasty judgement? It took me about 7 years of occasional study to get it.
We are glad to help you learn faster than I did, but you need to understand that this forum supports education about relativity and not debate about relativity.
Invutil said:
I wrote a paper, if anybody cares. But I'm done with debate for now.
Please Google "relativity of simultaneity" and/or "Lorentz transform". The problem is that you are assuming absolute simultaneity. If you do that, relativity will seem contradictory, but the problem is in your incomplete understanding of relativity, not relativity itself.
The OP has been banned for rules violations. Thread locked.
  • · Replies 16 ·
  • · Replies 25 ·
  • · Replies 130 ·
18K
