Should Beginners Learn C Before C++?
  • C/C++
  • Thread starter Thread starter Stephanus
    Programming
29 replies · 4K views
Stephanus
Dear PF Forum,
I read this link
Amine Quentin said:
Hi Guys
Do I need to learn C before C ++?
That makes me think, "How, straight with C++, do we teach programming language to someone who never knows progamming language?"
By "straight with C++" do you mean teaching someone who knows nothing about programming the OOP aspects of C++ without their knowing any of the sequential programming basics? If that's what you mean, I think it could only be done at a conceptual level. That is, you could give them a fair amount of solid information about the principles of OPP constructs but it would be a terrible approach to have them try to do useful programming from that point without their first going back and learning the basics of sequential programming.
I mean like your quote before Phinds.
Teaching the "c" first than later (much later) the "++".
I really love BASICA
No procedures, just line numbers.
No variable definition.
It's the easiest language to teach someone about programming language.
Later when they know how to program, we just skip GOSUB, RETURN, DEFINT, DEFDBL, DEF SEG, PEEK, POKE, and go straight to Pascal.
And introduce them with just:
Code:
program MyFirstProgram;
{ all variables here }
{ all goto Labels here }
begin
{ all the instructions here }
end.
I call this BASICing Pascal.
But on secound thought, I think it's wrong to introduce GOTO for someone who wants programming language for the first time.
When I taught an introductory programming course using C++, I used the following sequence, more or less:
  1. The basic process of writing, compiling and running programs (i.e. how to use programming tools), using very simple "Hello, world!" type programs that just do text output.
  2. Variables: int and double for numbers, and strings for text data. (Not char arrays and pointers; I used the 'string' data type.).
  3. Programs with both input and output.
  4. If-statements and loops.
  5. How to use functions that have already been written for you, e.g. library functions from the standard library.
  6. How to use member functions of objects that have already been written, e.g. strings and other objects from the standard library: myname.length() gives you the length of myname, etc.
  7. Grouping data together into vectors (I prefer these to plain old arrays) and structs.
  8. How to write your own functions, and design programs effectively using functions to organize tasks and sub-tasks.
  9. How to write your own classes (objects), and their member functions, and design programs to use them to organize your data and the actions that you do with them.
I've probably left something out; it's been ten years since I last taught that course.
Good steps.
But I didn't see pointer?
I find nowadays programmers don't know much about addressing modes.
I am lucky, I ever studied programming in DOS.
At least I can tell that in pascal: A = B + C; that would be
mov AX,
add AX,[C]
mov [A], AX
And all those segment : offset
I didn't do pointers until near the end of the course. Using the standard string data type means you don't need char*. Using vectors instead of arrays eliminates another place where pointers come up early in C. When passing stuff to functions I used references instead of pointers. The only thing left where pointers made sense was dynamic memory allocation using 'new' and 'delete'.
In fact, I remember having trouble coming up with a situation involving dynamic memory allocation that I could use to motivate introducing pointers. "OK, here's what I'd like to do, but none of the tools we've learned so far can accomplish it. So here's something new: pointers." I don't remember what I used. (Hey, it was ten years ago!) Probably something involving linked lists.
The guy who taught the upper-level computer science courses told me not to worry about it if I didn't do much with pointers. The students would study them in the computer architecture course anyway. That's where they did stuff like assembly language, addressing modes, etc.
"Nothing can accomplish it" A very good phrase for pointer introduction. I remember, 20 years ago I used to teach programming language when I was in college for some cash. Just fire the pointer away.
As I recall from many years ago, BASICA (and GWBASIC and several other variants of BASIC) had subroutines (called with GOSUB) and functions.
Code:
begin
end.
Stephanus said:
Good steps.
Nope, that isn't Pascal. For assignment, you use := .
Stephanus said:
that would be
mov AX,
add AX,[C]
mov [A], AX
Your first MOV instruction is missing something.
Sorry, you have sharp eye, Mark!
I typed to fast I think. I have been using pascal since 1990.
Code:
var
  A,B,C: Word;
begin
  A:=B+C;
  { assembly equivalence
  mov AX,[B]
  add AX,[C]
  mov [A],AX
end.
Should use Word or Integer in Turbo Pascal works fine. In Delphi, should be Word.
A little try (just try that this very time. 'Integer' doesn't work in Delphi in asm mode }
Code:
var
  A: Integer;
  B: Word;
begin
  B:=A; //works
  asm
    mov AX,A // syntax error
  end;
end;
I couldn't agree more. I started with BASIC on a C64 and produced nothing but spaghetti code just because it was possible. As BASIC was too slow to do something useful I then switched to assembler. That made it even worse. Learning programming this way was a really bad idea.
What bad idea? Using GOTO or go straight to assembly after BASIC?
Judging your first programming language is BASIC, I think you learned it at the 70's. If you study programming language in the 50's you'd be lucky just to have the punched card FORTRAN
Starting with programming languages that doesn't force me to structured programming.
But I find BASIC is very useful to teach someone the first programming language.
After the pupil is experienced enough. Writing a pascal triangle or fibonacci sequence, he/she should immediately be taught Pascal, then after that, is just choices.
That's what it is purposed for. And with a BASIC dialect that does not include GOTO it is even useful to teach good programming from the beginning.
Couldn't agree more. NO GOTO, GOSUB. At least not GOSUB. Switch to Pascal before GOSUB.
Why Pascal? I might be wrong, but as far as I know it's pretty much a dead language. After doing a little searching, I find that it still exists, though, as Delphi, which Borland sold off in 2008 to a company named Embarcadero.
I don't know of many schools that teach Pascal/Delphi, and we don't get a lot of questions about it here, so it would seem that not a lot of people are writing code with Pascal/Delphi.
Although the use of goto often leads to unreadable "spaghetti" code, and was excoriated in a paper by Edsger Dijkstra in 1968, its use is recommended in certain instances, such as for "end-of-function error handlers and for multi-level breaks from loops." -- Per Dennis Ritchie and Brian Kernighan from wiki article in link below.
https://en.wikipedia.org/wiki/Goto
Other programmers, such as Linux Kernel designer and coder Linus Torvalds or software engineer and book author Steve McConnell, also object to Dijkstra's point of view, stating that GOTOs can be a useful language feature, improving program speed, size and code clearness, but only when used in a sensible way by a comparably sensible programmer. According to computer science professor John Regehr, in 2013, there were about 100,000 instances of goto in the Linux kernel code.
Some quotes from Steve McConnell, in "Code Complete", pp. 348-349.
A well-placed goto can eliminate the need for duplicate code.
The goto is useful in a routine that allocates resources, performs operations on those resources, and then deallocates the resources.
In some cases, the goto can result in faster and smaller code.
Embarcadero still sells it for prices that nobody would pay just for fun. Thus there seem to be some professional users left. But I would also say that it is close to extinction.
Borland made a great marketing decision back when they released TurboPascal in 1983. As I recall, it sold for $49 (?), and they sold a ton of copies, and got a lot of people interested in programming. Back about '83 or so I had a version of UCSD Pascal that ran on Apple II computers. After I started learning C in '85, I was all done with Pascal.
Aside from Borland text editor which allow cursor to go up/down vertically :smile:, what I like about Pascal is its nested procedure.
It's very convenient to access local variable globally.
Code:
procedure Level1;
var
  A: Integer;
  procedure Level2;
    procedure Level3;
    begin
     A:=10; { don't have to put A in global scope }
    end;
  begin
  end;
begin
end;
And it's array definition which has a unique characteristic.
Pascal: var A: Integer[7..10];
Basic: dim A(10)
C: int a[10];
Pascal can set the element of the array from 7 not from zero, not a good programming technique tough. Has to leave this concept, because 99% of Delphi objects starts from 0
TStrings.Strings[Index] starts from zero
TList.Items[Index] starts from zero
TMemo.Lines[Index], TDataSet.Fields[Index], and almost many more.
But of course C++ has multiple inheritance which Pascal don't have.
And operator overloading is the most impressive feature in C++.
But nested procedure is the one that I need most in Pascal.
Pascal OOP has a unique characteristic than C++.
In C++ the inherited constructors) is called automatically. Is it good? Bad? I don't know.
But in Pascal we can delay calling inherited constructor.
Code:
constructor Square.InitSquare;
begin
  A:-10;
  B:=20;
  { some codes here }
  InitRectangle; { call the inherited constructor after some lines processed }
end;
But I know a kid, (not mine unfortunately :frown:), 13 years old, start doing Phyton.
https://en.wikipedia.org/wiki/GotoSome quotes from Steve McConnell, in "Code Complete", pp. 348-349.
GOTO is important for an experienced programmer. For a beginner it's a disaster.
It's like watching violence in GodFather. Good movie for adult, bad movie for children.
Sorry, Mark if I trouble you. It's just out of curiousity, why C is better than Pascal. I still doing C in Metatrader, I like C, but I think Pascal is better than C.
Perhaps if you could give me some enlightment...
Code:
procedure Level1;
var
  A: Integer;
  procedure Level2;
    procedure Level3;
    begin
    end;
  begin
  end;
begin
end;
Right, neither C nor C++ allows for functions to be nested inside other functions, although some current versions of C++ such as Visual Studio 2010 and later, allow the programmer to insert lambda expressions into a function or method. Lambda expressions are anonymous functions that are defined inline.
Python allows functions to be defined inside a function, though.
In your example above, you're not defining A globally -- it is local to Level1. Level2 and Level3 have access to variables defined at outer levels, which A is. If you had defined A inside Level3, it would not be visible to Level2 or Level1, so you wouldn't be able to access it "globally".
Basic: dim A(10)
C: int a[10];
IMO, it's only mildly convenient to be able to index arrays starting at other than zero. Many languages have this capability, among them Basic and Fortran.
Code:
begin
  A:-10;
  B:=20;
  { some codes here }
end;
If you write your own constructor in C++, rather than rely on a default constructor, you can have it do what you want.
I'm starting to learn Python, myself. I'm finding it to be a very interesting language with lots of unusual capabilities.
This is what we have to do in C. Move a to global.
Code:
int a; // accessed by level3
void level1()
  int a;
  a=50;
  level3();
  cout << a; / will output 50 instead of 20. C can't do that.
void level2()
void level3()
  a=20;
Code:
void level1()
  int a;
  a=50;
  level3();
  cout << a; // will output 50 instead of 20. C can't do that.
void level2()
void level3()
  a=20;
You don't have to do this, and it's usually not recommended. It's usually better to pass variables in the parameter list
C:
void level1()
  int a;
  a=50;
  level3(a);
void level3(int b)
  // level3 has read access to level1's a.
  printf("b is %d", b);   // prints "b is 50"
If level3 also needs write access, level3 can be rewritten so that the parameter is a pointer variable.
This is also supported by recent versions of Delphi.
Wow, I'm still using Delphi 3, 1996 version. I have a qr barcode library, can't find for the newer version. So I am stuck with it. I just realized, it's been 19 years. The longest programming language that I code.
