Should decay constants be equal when measuring the same property with different methods?
  • Thread starter lisab
    Decay
Staff Emeritus
I’m going to post this here even though this question straddles Chemistry and Physics. I think I know the answer but I’d like confirmation.
Let's say I am measuring a property P that is decaying exponentially, but I am measuring it using two different test methods. Let’s call them method A and method B.
The data from method A fit the curve:
P(t) = A0e-αt
The data from method B fit the curve:
P(t) = B0e-βt
In this case, I know the methods well enough that I know that A0 and B0 will be different numbers. But isn’t it true that α = β?
If you are measuring the same property, but getting different results, something is wrong. And if something is wrong, everything can go wrong (that is, if A0≠B0, I don't see why to expect α=β).
Is it just an experimental error, or is there more to the difference between both methods?
If α = β, but A0<B0, then the first curve is less then the second curve everywhere.
In other words, they cannot fit the same data regardless of systematic or experimental errors.
Therefore, if A0≠B0 then that implies α≠β.
OK, mystery (sort of) solved.
Turns out there are two typos. One, the author accidentally used the same variable for the exponent. Two, in a graph showing results from both tests, there are supposed to be two sets of axes but only one got into the report.
I didn't notice the first typo but it was the graph that made my head spin. The units weren't right -- method A and method B give results in different units, so I was confused :rolleyes:!
Thanks, Borek and ILS.
