Is There a Simple Way to Show GL(n,C) is a Lie Group?
  • Thread starter Thread starter ergospherical
    Group Lie group
The discussion focuses on demonstrating that the general linear group ##\mathrm{GL}(n,\mathbf{C})## is isomorphic to a subgroup of ##\mathrm{GL}(2n,\mathbf{R})##, establishing it as a Lie group. The approach involves using a matrix block representation to show that the mapping preserves group operations, specifically verifying that ##\Phi(XY) = \Phi(X) \Phi(Y)##. Key insights include the polynomial nature of multiplication and inversion operations, which confirm the smooth structure necessary for a Lie group. The discussion also references the derivative of the determinant and provides links to further resources for deeper understanding.
  • Understanding of Lie groups and their properties
  • Familiarity with complex and real matrix representations
  • Knowledge of polynomial functions and their smoothness
  • Basic concepts of group theory and isomorphisms
  • Study the properties of Lie groups and their subgroups
  • Learn about the structure of ##\mathrm{GL}(n,\mathbf{C})## and ##\mathrm{GL}(2n,\mathbf{R})##
  • Explore the implications of polynomial functions in the context of Lie groups
  • Investigate block matrix multiplication and its applications in group theory
Mathematicians, particularly those specializing in algebra and geometry, students studying Lie groups, and researchers interested in the applications of complex and real matrix theory.
ergospherical
Education Advisor
Insights Author
As per title
N/A
I'd like to clarify a few things; the approach is basically just to show that ##\mathrm{GL}(n,\mathbf{C})## is isomorphic to a subgroup of ##\mathrm{GL}(2n,\mathbf{R})## which is a smooth manifold (since ##\mathbf{R} \setminus \{0\}## is an open subset of ##\mathbf{R}##, so its pre-image ##\mathrm{det}^{-1}(\mathbf{R} \setminus \{ 0\}) = \mathrm{GL}(2n,\mathbf{R})## under the continuous determinant map is a smooth manifold.)
The hint is to consider replacing each ##X_{ij} = a_{ij} + ib_{ij}## with a matrix block ##\begin{pmatrix} a_{ij} & -b_{ij} \\ b_{ij} & a_{ij} \end{pmatrix}##. To show this map is a group isomorphism means to show that ##\Phi(XY) = \Phi(X) \Phi(Y)##, right? So I could write (summation implied over repeated suffices)\begin{align*}
(XY)_{ij} = X_{ik} Y_{kj} &= (a_{ik} + ib_{ik})(c_{kj} + id_{kj}) \\
&= a_{ik} c_{kj} - b_{ik} d_{kj} + i(a_{ik} d_{kj} + b_{ik} c_{kj})
\end{align*}I tried to write the affect of the map ##\Phi## on the elements explicitly, i.e. \begin{align*}
\Phi(X)_{ij} =
\begin{cases}
a_{\mathrm{ceil}{\frac{i}{2}} \mathrm{ceil}{\frac{j}{2}}}, & i+j \ \mathrm{even} \\
(-1)^i b_{\mathrm{ceil}{\frac{i}{2}} \mathrm{ceil}{\frac{j}{2}}}, & i+j \ \mathrm{odd}
\end{cases}
\end{align*}but this becomes a mess to work out ##(\Phi(X) \Phi(Y))_{ij}##. I think it is clear, by considering e.g. a ##1 \times 1## matrix ##(a_{11} + ib_{11})##, that it works, but there is surely a better approach?
For two nxn matrices (which expand to 2nx2n) you should be able to convince yourself that if you just look at the first two rows of X and the first two columns of Y, that if the multiplication works out that it will work out for the rest of the rows) columns. Then you have a much more tractable problem, just pick an arbitrary 2x2 block in the result and check that e.g. the top left entry is the sum of product of real parts of the original n complex numbers minus sum of the product of the imaginary parts.
Likes ergospherical
Part of the longer way , in showing product and inversion are smooth is using that both of these are polynomials on the entries. And for a Lie Group, a subgroup is also a Lie Group if it's a closed subgroup.
Multiplication are linear polynomials, hence analytic. Inversion, too, extended by the inverse of the determinants as a factor. But they are quotients of polynomials without singularity, hence analytic as well.
Here is the calculation for ##T_{\operatorname{id}}(\operatorname{SL}(n)) = \mathfrak{sl}(n)##
https://www.physicsforums.com/insights/pantheon-derivatives-part-iv/
It contains the derivative of the determinant.
Likes ergospherical
  • · Replies 36 ·
