Show series [sin(n)]/n converges?
  • Thread starter erjkism
    Series
51 replies · 113K views · last reply
erjkism
[tex]\Sigma\frac{sin(n)}{n}[/tex]
from n=1 to infinity
i have to show that this series converges, but that it doesn't converge absolutely.
the thing is, I figured th
if you say that the top of the equation is -1<sin(n)<1, you can then take the absolute value to get 0<sin(n)<1. so then the equation can look like this:
[tex]\Sigma\frac{1}{n}[/tex] from n=1 to infinity, which is a divergent series. i just don't know how to show that the original equation is convergent.
Try to use D'alemberts test for convergence of series.
[tex]\lim_{n\to\infty}\frac{a_n_+_1}{a_n}=L[/tex] if L<1 it converges if L>1 it diverges if L=1 this criterion does not give any answer.
okay so i tried that, but I'm having a tough time figuring out the result of that limit.
[tex]\frac{n sin(n+1)}{(n+1)sin(n)}[/tex]
I am still stuck with a bunch of sin functions... I am not sure if this is the right thing to do
it seems it doesn't work after all!
Keep in mind that sin(x) never goes above 1 or below -1, but oscillates infinitely often as x approaches infinity. So you are really left with:
[tex]\frac{n}{n+1}[/tex]
and as n approaches infinity you can drop the constants and your limit is equal to 1, making the test inconclusive.
Maybe try using the fact that [tex]\sum\frac{(-1)^{n}x^{2n+1}}{(2n+1)!} = sin(x)[/tex] n=0 -> infinity from taylor series expansion of sin(x).
Plugging that in you get a double summation that will oscillate between -1 and 1 for all values of x, I think.
The series doesn't alternate in any sort of reasonable pattern which I think puts this outside of the set of elementary problems. What course are you taking?
its just a problem that i need to do for calculus 2 at college... so i don't know much more than what's been talked about here already
Compare it to its integral. It's quite famous, its called the Dirchlet integral. Take a look at its proof of conditional convergence on the net, and if you think it's too advanced, either try another method or skip this question, or if you think the proof is reasonable, then its good =]
According to Wikipedia, the Dirichlet Integral is the integral of the same function as has been discussed, but evaluated from zero to infinity instead of the one to infinity to be considered here. Surely evaluation at zero and one would make a difference here since we are dealing with a trig. function?
I've tried applying the Integral Test to this and it concludes divergence.
Try the result on wikipedia. Thats more of a proof of its exact value though, more than what you need.
You CANNOT do that. The integral test is only strictly valid for monotone functions. I think this problem landed in a calc 2 course by mistake.
no, our teacher told us that we have the ability to do it, but it is just pretty difficult. he won't help me... someone save me!
Ok, then maybe it's not so godawful hard. Here's some things to try. You can sum a series like r^n/n by differentiating with respect to r and obtaining a geometric series. sin(n)=Im(exp(in)). So your series can be written as Im(exp(i)^n/n). Try that and see where it takes you. I'll check back later and see how you are doing... It's debatable whether this is a 'proof' of convergence though. You're assuming the limit exists to begin with.
If you can do following?
-1/x <sin(x)/x <1/x
1/x and -1/x converge(?)
so does sin(x)/x?
I don't think anyone has suggested this; maybe because I skimmed the thread too fast or this is wrong.
Dick, I'm not sure what you're doing up in your previous post, though it may just be the notation...
Anyways, I'm in ap calc bc, which is pretty much like calc 2 I guess.
I had to get kind of "creative" with it so I don't know if everything I did is exactly legit. So here's my answer and reasoning: (I've omitted the sigma notation for ease here)
sin(n)/n is + when n:(0,pi) and - when n:(pi,2*pi) therefor the sign changes every pi.
sin(n)/n already looks a lot like (-1)^n/n so I tried to figure out a way to get (-1)^n to alternate like sin(n) does. My first impulse was to use (-1)^(n/pi) but that leads to a problem since that would give you odd/even values for the exponent alternating infinitely fast. So, you've got to keep that exponent restricted to integers.
This brings me to the floor() function (this is my "creative" part). I've never used this in formal math, but its pretty similar to [|x|] in that it rounds down the nearest integer which is just what I need to deal with that icky exponent. I also checked a few numbers really quick to make sure that my (-1)^floor(n/pi) had the same sign at sin(n) for various n's so I could actually compare them without getting into more problems.
So, that gives me (let's pretend "E" is the equivalent to a sigma)
n=1 to inf. E(-1)^floor(n/pi)
This converges by the alternating series test. Which I spare us all from reading (and me from typing!), I'm sure you know how it goes.
So we know n=1 to inf. E(-1)^floor(n/pi) converges and we want to show that n=1 to inf. Esin(n)/n converges. Direct comparison isn't an option since the terms have to be greater than zero so I went with the limit comparison test.
sin(n)/n * n/((-1)^floor(n/pi)) = sin(n)/((-1)^floor(n/pi))
this result is a constant number. It will always be positive since the alternating signs of the two functions always end up canceling each other out in the series since n is an integer. Also the resulting ratio will never equal zero as n is restricted to integers so there is no way to get an irrational number like pi (and you skip zero since n starts at one) which would result in the sin(n) = 0.
since you get a number greater than zero from the limit comparison test by comparing it with a convergent series the series n=1 to inf. Esin(n)/n converges!
...that was so much shorter on paper...
-1/x <sin(x)/x <1/x
so does sin(x)/x?
neither -1/n nor 1/n converge.
(-1)^n/n does, however, converge.
Thanks ;)
I thought sequences should be little different from series.
Anyways, I'm in ap calc bc, which is pretty much like calc 2 I guess.I had to get kind of "creative" with it so I don't know if everything I did is exactly legit. So here's my answer and reasoning: (I've omitted the sigma notation for ease here)
since you get a number greater than zero from the limit comparison test by comparing it with a convergent series the series n=1 to inf. Esin(n)/n converges!...that was so much shorter on paper...
Well, that does show some creative thinking. And I think you know what some of the problems here are. But, I don't believe you. Because the sum of (-1)^floor(n/pi) DEFINITELY does not converge in any sense. It is not alternating for one thing, but it's biggest defect is that the terms don't even approach zero. No such thing can converge. What I'm suggesting is to use the Euler formula to express sin(n) as a the imaginary part of the power of a complex exponential. This makes the problem look closely related to a geometric series of dubious convergence. I'm kind of waiting to the OP to explore this before getting too specific.
Wont.
[itex]\sum_{n=0}^{-\infty}\frac{sin(n)}{n}\;dn \rightarrow -\frac{1}{2}\pi[/itex]
[itex]\sum_{n=0}^{\infty}\frac{sin(n)}{n}\;dn \rightarrow \frac{1}{2}\pi[/itex]
[itex]\int_{-\infty}^{\infty}\frac{sin(n)}{n}\;dn -\int_{-1}^{1}\frac{sin(n)}{n}=2si(1)\rightarrow=\pi-2si(1)[/itex]
Where si is the sigmoid function.
So
or putting it in terms of convergence the top divided by the bottom as the limit approaches infinty "converges" to [itex]\pi[/itex]-2si(1)
Because
1/2 of that = 1/2[itex]\pi[/itex] and 1/2 of the other =[itex]-\pi[/itex]?
so because of that we get the unusual result:
[tex]\frac{\frac{sin(n)} {\infty}} {{n}{\infty}}=\pm\frac{1}{2}\pi \lim_{n\rightarrow\pm\infty}-2si(1)[/tex]
That's meant to be [itex]\frac{n}{\infty}[/itex] in the denominator but for some reason latex won't do it.
Actually that's a really weird way of putting it but it should converge to pi given that if we accept that -2(si) is a definite result or that +/- infinity- that is in fact pi. In other words no it does not converge unless we accept that it must have a solution that doesn't involve a non elementary function. :smile: If we don't then there is no solution, it does not converge.
The latex in that isn't correct, and I can no longer edit it. But I think you get the point? Or have I just confused you and myself? :smile:
Should be:
[tex] \frac{\frac{sin(n)} {\infty}} {n/\infty}=\pi \lim_{n\rightarrow\pm\infty}-2si(1)[/tex]
[itex] \int_{-\infty}^{\infty}\frac{sin(n)}{n}\;dn \rightarrow\int_{-1}^{1}\frac{sin(n)}{n}=2si(1)\rightarrow=\pi-2si(1)[/itex]
Or [itex]\pi-\frac{dP}{dt}=P(1-P).[/itex]
Or [itex]\pi[/itex] -
http://en.wikipedia.org/wiki/Image:Logistic-curve.png
Graph of a logistic S-shaped curve, rising from near 0 at x = -6 to near 1 at x = 6, crossing 0.5 at x = 0; axes labelled 0 to 1 vertically and -6 to 6 horizontally.
I bet that makes no sense whatsoever. :smile:
[itex] <br /> 1. \int_{-\infty}^{\infty}\frac{sin(n)}{n}\;dn \rightarrow\int_{-1}^{1}\frac{sin(n)}{n}=2si(1)\rightarrow=\pi-2si(1)\; \text{given eq 1.}+2si(1)=\pi \;or \; \text{or does not converge}<br /> [/itex]
And that should be so it converges to pi or does not converge according to how you want to float your boat.
? This problem has NOTHING to do with the sine integral, Si. Nor is the sum pi/2. I'll give you all a big hint. I summed 1000000 terms of the series. I get about 1.0708. It converges pretty slowly like a harmonic series. I also know a combination of elementary functions that gives me that number. I found this by following my own suggestion. So I believe it's correct. 1.0708 won't tell you what the answer is, but it will tell you when your answer is wrong. And 1.0708 is NOT pi/2.
Actually, I was talking about the integral of that.
as in between the range of -\infty to infty.
And between 1 and infinity and 1 and 1.
if the integral is this then in sum form it is this.
Then we can work out if the integral of sin(n)/n converges? Does that make more sense?
I was trying to prove that in fact the integral of 1 to infinity that equation is 1/2 pi because the total integral from negative infinity to infinity is pi-2si(1).
I was wondering if that is a fair assumption, I can see how it might of looked like I was trying to answer the op though, my bad. What I should of done is prefaced it with say if we have the integral here, how do I prove that it does or does not converge?
Can we prove that it is equal to pi on its own or to pi-si(2) or that there is nos substantive difference between the two? Does that make sense, if not, sorry. I was just thinking aloud you know?
As for the sequence well that's another matter. Sorry. And one that I think have enough clues there to solve it now.
Unfortunately I cannot edit any of my posts so I'm stuck with explaining it here. :smile:
Obviously if I type the summation into a program it gives me a pretty good answer, so I'll not go there. :smile:
If you are just messing around with the integral knowing it has nothing to do with the series, I'm not sure this is the place to do that. It's going to confuse the OP.
K my bad. Is it fair to say that there is no substantial or significant difference between the answer pi and pi-si(2) though? Is what I was asking? Or would that be an erroneous assumption?
I'll delete those posts if I can. And this one if you like pm me. or spoiler an answer.
It's pretty obvious there there is a difference between pi and pi-si(2). For one thing, they are different numbers. I don't know what your question is. Can you compose it in a different thread? I'd be happy to look at it there.
Sure. It was only the idea that -Si(1) and -Si(1) may cancel given an infinite spectrum and thinking pictorially about the wave, ie if we look at it terms of an overall number. But I think I can see why that is wrong now, ie they function is not a mirror function either side of 0, so never mind. It was just an idle speculation, apologies for the thread jack, I've asked for the posts to be deleted so as to avoid confusion.
My bad :( Sorry for misleading the OP !
I very much like that solution :D Excellent work Dick =]
None of the solutions are acceptable yet considering the student is in AP Calculus. And sadly that includes using DeMoivre's formula (that's right many students that you think would know that formula by AP Calc don't!). There must be a solution only using the standard tests that they are taught (limit comparison, ratio, root, integral, etc), and it should be just a few lines long.
That's a very interesting question. I agree Dick's method is very nice and seems to work. However I also agree that the techniqes used might be too advanced.
A proof using only elementary comparison tests and the like would certainly be much more technical and I see no reason why it should be only a few lines long. I did something similar some time ago maybe I can find my notes.:smile:
