Show that if f: A → B and E, F are subsets of A, then f(E ∪ F) = f(E)
  • Thread starter Thread starter Scienticious
    Subsets
The discussion centers on proving the equality f(E ∪ F) = f(E) ∪ f(F) for a function f: A → B and subsets E, F of A. The proof is structured by demonstrating that each element in E or F maps to an element in f(E) or f(F), respectively, thus establishing the necessary subsets. The participants emphasize the importance of clearly showing both directions of the proof to confirm the equality, and a revised proof is presented that successfully illustrates this logic.
  • Understanding of functions and their mappings, specifically f: A → B.
  • Familiarity with set theory concepts such as unions and subsets.
  • Basic knowledge of mathematical proofs and logical reasoning.
  • Experience with element-wise arguments in set relations.
  • Study the properties of functions and their images under unions of sets.
  • Learn about formal proof techniques, including direct proofs and proof by cases.
  • Explore set theory in depth, focusing on operations like union, intersection, and subset relations.
  • Practice constructing proofs involving functions and set operations to reinforce understanding.
Mathematics students, particularly those studying abstract algebra or set theory, as well as educators looking to enhance their teaching of proof techniques and function properties.
Scienticious
Show that if f: A → B and E, F are subsets of A, then f(E ∪ F) = f(E) ∪ f(F).
My attempt:
Suppose x is an element of E. Then f(x) is an element of f(E), which means f(x) is a subset of f(E).
But x is in E implies x is in E or F so that x is in E ∪ F.
Thus f(E ∪ F) = f(x) is a subset of f(E), and is also a subset of f(E) ∪ f(F) by or introduction.
*Similar argument applies when we suppose x is an element of F*
Now I'm having trouble with the converse part of the proof; the only idea I've come up with is to use a similar strategy as in the first proof and suppose x is in E so that f(x) is in f(E). Then you can show that since x is in E or F that the left side of the equation is contained in the right.
I'm a total newbie at proofs. please someone help me out :3
Just some formalities: In the first line you say f(x) is a subset of f(E). The More correct thing to say is that for x\in E, f(x)\in f(E), i.e. f(x) is an element in f(E). But what you really want to say is this: Let x\in E so that f(x)\in f(E). Then continue as you did: since x\in E, x\in E\cup F, and thus
f(x)\in f(E\cup F). This shows f(E)\subset f(E\cup F). The same argument applied to x\in F will give f(F)\subset f(E\cup F) which together yield
f(E)\cup f(F)\subset f(E\cup F).
Saying f(E\cup F)=f(x) and that last line you wrote don't make sense to me. The idea is to start with an element from one side of the equation and then show it must also belong to the set on the other side of the equation : If you want to prove A=B, you need to show that if x belongs to A, it also belongs to B ( A is a subset of B), and ten you need to show if x belongs to B it also belongs to A (B is a subset of A). Together (A is a subset of B) and (B is a subset of A) yield B=A. Does this make sense to you? you need to keep track of where you start and make sure you understand what is going on!
This side of the proof we want to show that f(E\cup F)\subset f(E)\cup f(F). to do this you need to start with something like : Let x\in E\cup F so that f(x)\in f(E\cup F). Then you brake it into two cases, either x is in E or x is in F (or both). Try rewriting your argument and post what you get.
Thank you for your reply :3 I think I get it now; here's my new proof:
Let x be an element of E.
Then f(x) is an element of f(E).
But if x is an element of E then x is an element of E ∪ F
Thus f(x) is an element of f(E ∪ F).
Therefore f(E) is a subset of f(E ∪ F).
Now let x be an element of F.
Then f(x) is an element of f(F).
But if x is an element of F then x is an element of E ∪ F.
Therefore f(F) is a subset of f(E ∪ F).
Together these two cases imply that f(E) ∪ f(F) is a subset of f(E ∪ F).
Conversely, let x be an element of E ∪ F so that f(x) is an element of f(E ∪ F).
Case 1: x is an element of E. Then f(x) is an element of f(E).
By or introduction, f(x) is also an element of f(E) ∪ f(F).
Therefore if x is an element of E then f(E ∪ F) is a subset of f(E) ∪ f(F).
Case 2: x is an element of F. then f(x) is an element f(F).
Therefore if x is an element of F, f(E ∪ F) is a subset of f(E) ∪ f(F).
These two cases together imply that f(E ∪ F) is a subset of f(E) ∪ f(F).
Since f(E U F) is a subset of f(E) ∪ f(F), and vice versa, these two sets are equal.
Hence f(E ∪ F) = f(E) ∪ f(F).
qed
The other thought I had for the 2nd part of the proof would be to consider 3 cases: x is in A/B, B/A and A ∩ B.
But as I understand it my proof should work.
Thanks again for your help :3
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
10K
