Show that it satisfies the differential equation
The discussion centers on demonstrating that the function y=tanh(t) satisfies the differential equation dy/dt=1-y² with the initial condition y(0)=0. Participants detail the integration process and manipulation of the equation, ultimately confirming that the left-hand side equals the right-hand side. Additionally, the conversation explores a related function y=Atanh(Bt) and its satisfaction of the differential equation dy/dt=AB-(B/A)y², emphasizing the importance of substitution and algebraic simplification in solving differential equations.
  • Understanding of differential equations, specifically first-order ordinary differential equations (ODEs).
  • Familiarity with hyperbolic functions, particularly tanh and sech.
  • Proficiency in integration techniques, including integration by substitution and partial fractions.
  • Knowledge of initial conditions and their role in solving differential equations.
  • Study the properties and applications of hyperbolic functions in differential equations.
  • Learn about the method of separation of variables in solving ODEs.
  • Explore the concept of initial value problems and their significance in differential equations.
  • Investigate the relationship between air resistance and velocity in physics, particularly in the context of differential equations.
Students studying calculus and differential equations, particularly those preparing for exams involving ODEs and hyperbolic functions. This discussion is also beneficial for educators seeking to clarify concepts related to solving differential equations.
crybllrd
Show that
y=tanh(t)
\frac{dy}{dt}=1-y^{2}
with initial conditions y(0) = 0
I'm not sure how to start, but we have only dealt with one D.E., and we had moved all the variables to a respective side then integrated.
dy=(1-y^{2})dt
\frac{dy}{1-y^{2}}=dt
Integrate both sides to get
ln|1-y^{2}|=t
Not sure where to go from here
hi crybllrd! :smile:
ln|1-y^{2}|=t
nooo :redface:
d/dy (ln(1 - y2)) = 2y/(1 - y2)
try again, splitting 1/(1 - y2) into partial fractions first :wink:
Oh ok , I got it. I am in Calc 2 and when I read Diff. Eq. it just scared me off.
That was easy enough. It is a seven part question, and the third part looks very similar:
Show that for the arbitrary constants A and B, the function y=Atanh(Bt) satisfies:
\frac{dy}{dt}=AB-\frac{B}{A}y^{2}
I will try to get it to match the form:
\int\frac{1}{A^{2}+x^{2}}=\frac{1}{A}tan^{-1}(\frac{x}{A})+c
_______________________________________________________
dy=B(A-\frac{1}{A}y^{2})(dt)<--- factored out the B and multiplied by dt
\frac{dy}{A-\frac{1}{A}y^{2}}=Bdt
It looks like I need to do a little more manipulation/simplification to get the left side where I want it (namely getting rid of the 1/A in the denominator) but I can't get it to the form I want.
No, no, no! Did you not understand what sheriff89 said? You are not asked to solve the differential equation. In Calculus II you wouldn't be expected to do that.
Differentiate y= Atanh(Bt) and put it and y^2= A^2tanh^2(Bt) into the equation and determine if you get a true equation or not.
Why would I put the y^2 into the equation and square the other side? And what is a "true equation"?
I have a feeling these will be on our exam next week, so I want to understand it well.
Thanks
You still aren't getting the point of just substituting into the differential equation to show you have a solution. Go back to the first one. If y=tanh(x) then dy/dx=sech(x)^2. The other side is 1-y^2=1-tanh(x)^2. Aren't they equal? You don't have to solve any ODE's, you just have to show you have a solution.
Oh ok I get it.
On part A I algebraically rearranged to get dy/(1-y^2 )=dt, then I integrated both sides to get (after simplification) y= tanh⁡t, done. Just did it the long way, not even thinking because all the other problems were integration.
then, when I started integrating part b, people starting getting upset :P
So this is what I have for part b:
y(t)=Atanh(Bt)
y(t)'=ABsech2(Bt)
y(t)'=AB-(B/A)y2
ABsech2(Bt)=AB-(B/A)Atanh2(Bt)
B's cancel out
Asech2(Bt)=A-tanh2(Bt)
I can see this being true if A=1
Is that all I need?
And, where does the y(0)=0 come into play? I see where that is true, but is that information actually needed to solve it?
y(t)^2=A^2*tanh(Bt)^2. If you work it out correctly the A factor will cancel as well. And you don't need y(0)=0 to show that. But given the solution, you can say y(0)=0.
Cool, thanks a lot.
I think I'm definitely ready for an exam on Monday.
EDIT: I had a math error on my last post when I substituted for y2. When done properly, all the A's canceled out.
Ugh, this problem is killing me. On a later part, it asks:
Let v(t) be the velocity of a falling object of mass m that started from rest. For large velocities, air resistance is proportional to the square of velocity v(t)2.
If we choose coordinates so that v(t)>0 for a falling object, then there is a constant k>0 such that
\frac{dv}{dt}=g-\frac{k}{m}v^{2}
Solve for v(t) by applying the rsults of part (b) (what I just worked out) with
A=\sqrt{gm/k}, B=\sqrt{gk/m}
I am not sure what "result" he is wanting from part B, I just had to show that a function satisfied a differential, and in doing so I canceled out all of the constants except for the B within the hyperbolic.
You know that v(t)=A*tanh(Bt) satisfies \frac{dv}{dt}=A B - \frac{B}{A}v^{2}. So to find a solution to \frac{dv}{dt}=g-\frac{k}{m}v^{2} you just set A B=g and \frac{B}{A}=\frac{k}{m} and solve for A and B. But it looks like they already did that for you as well. So maybe they just want to to substitute those values for A and B into v(t)=A*tanh(Bt)? Or maybe they want you to show explicitly that it works?
Alright I just did both. Thanks again.
  • · Replies 21 ·
