Show that n+2 is not a perfect square
  • Thread starter Thread starter opt!kal
    Square
This discussion focuses on proving that if n is a perfect square, then n+2 cannot be a perfect square, using a proof by contradiction. The participants establish that if n = k² and n+2 = p², then the equation (p - k)(p + k) = 2 must hold. They conclude that the only integer factors of 2 lead to contradictions when solving for k and p, confirming that n+2 cannot be a perfect square.
  • Understanding of perfect squares and their properties
  • Familiarity with proof by contradiction techniques
  • Basic algebraic manipulation, including factoring
  • Knowledge of integer properties and factorization
  • Study the properties of perfect squares in number theory
  • Learn more about proof techniques, particularly proof by contradiction
  • Explore the concept of integer factorization and its applications
  • Investigate related problems involving differences of squares
Mathematics students, educators, and anyone interested in number theory and proof techniques will benefit from this discussion.
opt!kal
Hi there,
I've been having a lot of trouble with this particular proof lately, and I just do not know how to finish it up:
Show that if n is a perfect square, then n+2 is not a perfect square.(show by contradiction)
none that I know of
Since its a proof by contradiction, I know that I can rewrite it in the form: p ^ not q.
So I have: n is a perfect square, and n+2 is a perfect square.
Since I assume that then I have that n = k^2 and n+2 = p^2
So then I'll have (k^2) + 2 = p^2
At this point I basically get confused. I just have no idea on how to proceed from here, my only guess is that I should do two cases, one where k is even and one where k is odd, and show for each case that p^2 will end up like the case, while p will end up as the opposite (i.e. if I do the even case, then try to show that p will end up odd). But I have absolutely no idea on how to accomplish that. Any help would be greatly appreciated!
-3^2 = 9
-2^2 = 4
-1^2 = 1
0^2 = 0
1^2 = 1
2^2 = 4
3^2 = 9
4^2 = 16
And so on.
Regardless of what integer you're squaring, no two perfect squares are a distance of 2 apart. It is 1, 3, 5, 7, etc.
Goldenwind said:
-3^2 = 9
-2^2 = 4
-1^2 = 1
0^2 = 0
1^2 = 1
2^2 = 4
3^2 = 9
4^2 = 16
And so on.
But how would you prove that statement?
opt!kal said:
Hi there,
none that I know of
You almost have it. Saying that k2+ 2= p2 is the same as saying p2- k2= 2. Since the left side is the difference of two squares, that is the same as (p- k)(p+k)= 2. That is, p-k and p+k are integer factors of 2. But 2 only has 1, -1, 2, and -2 as integer factors. Can you finish it from there?
Yeah I think I see what you're saying. So basically for (k + p)(k - p) = 2 to hold, k and p can only be -2, 2, -1, 1. However, plugging each one in, you see that they will not equal to 2, so that means that the assumption that n + 2 is a perfect square does not hold? Does that seem right? Thanks in advance!
No, p and k do not need to be -2, 2, -1, or 1. Only p+k and p-k need to be -2, 2, -1, 1.
Exactly. And since k and p are positive integers, what can they be if p+ k and p- k are -2, 2, -1, or 1?
Hrmmm, I think I see what's you're trying to say... So I set p + k = 2 and p - k = 1 and solve right? then do p + k = 1 and p - k = 2...and do the same thing for the negative cases, and solve for p and k, which I don't think will end up as integers...and since an integer a is a perfect square if there is an integer b such that a = b^2, a contradiction occurs? (sorry for the late reply, just got bogged down by other work) Thanks in advance!
  • · Replies 24 ·
