Show the limit exists or does not exist
  • Thread starter Thread starter vantz
    Limit
The discussion revolves around determining the existence of a limit as (x,y) approaches (0,0) for the expression [xy]/(x^2+y^2). Initial attempts to find the limit by substituting various values consistently yield 0, leading to confusion about the limit's existence. However, a key insight reveals that by rewriting the limit and factoring the numerator, the limit approaches different values depending on the path taken—specifically, 1/2 and 0. This indicates that the limit does not exist due to the discrepancy in results from different approaches. Ultimately, the conclusion is that the limit does not exist.
vantz
c2f1f923-74de-46af-bb68-3ccd4efeb33a.jpe
it does not exist, but i can't get different limits, I am only getting it approaches 0
i replaced x=1 only, y=0 only, y=x, x=y but I'm only getting 0 as my limit.
thanks
this is a trick. notice it is equivalent to finding the limit of [xy]/(x^2+y^2) as (x,y)-->(0,0).
this one is very familiar, and is done by letting x=y.
im still approaching 0 when x=y
You shouldn't be. Replacing y with x:
\lim_{(x,y) \to (0,0)} \frac{x*x}{x^2+x^2} = ...
oh so first i rewrite the limit into a more familiar one and then solve. but i don't see how they are related.
edit:nvm i got it.
thanks
Yes, if you let x=1, and take the limit of the result as y→0, the limit is zero.
Similarly, letting y=0 and taking the limit of the result as x→1, also gives zero.
Use these results along with the limit obtained as others have suggested. What's your final conclusion?
i showed the relation between the original limit and [xy]/(x^2+y^2) as (x,y)-->(0,0).
numerator factorizes to y(x-1), then i replaced (x-1) with t, and as x→1, t→0. new limit does not exist because it approaches 1/2 and 0.
Correct !
