Showing stability under scaling and additivity of distriubtions
  • Thread starter Thread starter stukbv
    Scaling Stability
To demonstrate the properties of gamma distributions, it is established that if X ~ r(a1, B) and Y ~ r(a2, B) are independent, then X + Y follows a gamma distribution with parameters r(a1 + a2, B). The moment-generating function (mgf) approach confirms this result, provided it is expressed clearly. For the second property, the transformation of a random variable cX involves adjusting the probability density function (pdf) and cumulative distribution function (cdf) accordingly, leading to the conclusion that cX ~ r(a1, cB). The discussion emphasizes the importance of clarity in mathematical expressions and understanding the underlying principles of distribution transformations. Overall, the thread provides insights into the stability and additivity of gamma distributions under scaling and addition.
stukbv
I need to show that if X ~ r(a1,B) Y ~ r(a2,b) where r means gamma distribution then if X and Y are independent
i) X+Y ~ r(a1+a2,B)
ii) cX ~ r(a1,cB)
i) i use the mgfs of x and y and ended up with mgf(x+y) = (1/1-Bt)^(a1 + a2 )
I am told this is enough to prove i, is this correct or what could i say to make it better?
ii) i am a bit stuck on this one, i mean, would you just put c in front of all the x's in the pdf and then re-derive the mgf? or is there something extra?
thanks
i) X+Y ~ r(a1+a2,B)
ii) cX ~ r(a1,cB)
thanks
I suppose your "i" is supposed to be "I", rather than the square root of -1? Anyway, your result in (i) would be OK if you wrote it properly, with brackets to make things clear. That is, instead of writing (1/1-Bt)^(a1+a2)---which equals [1 - Bt]^(a1+a2)---you should write 1/(1-Bt)^(a1+a2), or (1 - Bt)^(-a1-a2) or (1-Bt)^{-(a1+a2)}. As to (ii): what is the problem? If f(x) is the density function of a random variable X, what is the density function of Y = c*X for a constant c? Alternatively, if F(x) is the (cumulative) distribution function of X, that is, P{X >= x} = F(x), then what is the cumulative distribution of Y = c*X? Then you can differentiate the distribution to get the density.
RGV
Is this where I say X = Y/c so then i put into fx y/c in place of all x's and then multiply by 1/c to get fY?
If F(x) = P{X <= x} and Y = c*X (with c > 0 a constant) then P{Y <= y} = P{c*X <= y} = P{X <] y/c} = F(y/c). The density of Y is g(y) = (d/dy)F(y/c) = f(y/c)/c, where f(x) = probability density of X. Alternatively: g(y)*dy = P{y < Y < y+dy} = P{y < c*X < y+dy} = P{y/c < X < y/c + dy/c} = f(y/c)*dy/c, so g(y) = f(y/c)/c. So, the answer to your question is YES, but I much prefer to get it from first principles.
RGV
Ok so now I have 1/c ( 1/(r(a)B^a) * (y/c)^a-1 .e^(-y/cB)
Is that right ?
I don't know. You have all the formulas you need.
RGV
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
