Silly question about trig past pi/2
  • Thread starter Thread starter motornoob101
    Trig
Understanding angles beyond \(\pi/2\) can be challenging, particularly with inverse trigonometric functions like arctan. The arctan function typically returns values between \(-\pi/2\) and \(\pi/2\), which means for \(\tan^{-1}(-1\), the correct angle is \(-\pi/4\) or equivalently \(7\pi/4\) when considering the full circle. However, if restricted to the interval \([0, \pi]\), arctan(-1) does not yield a valid result, as it does not fall within this range. It's important to recognize that the choice of interval affects the output of inverse trig functions, and the common interval for arctan is \([- \pi/2, \pi/2]\). Thus, when asked for values within specific intervals, one must carefully consider the defined range and properties of the function.
motornoob101
I know all the well know angles from 0 to \pi/2. However, past pi/2 I am rather clueless and have no idea what angle corresponds to what value.
For example, in trying to figure out tan^{-1}(-1) How does one know it is 5pi/4 and not 7pi/8? I was debating between measuring pi/4 from the negative x-axis (which would give me 7pi/8) and measuring pi/4 from the y axis,(which would give me 5pi/4) but as you can see, I choose the wrong value. Is there a trick to it? Thanks.
Mathematics news on Phys.org
well
arctan(-1)=-arctan(1)=-\frac{\pi}{4} so it means that \frac{\pi}{4} lies on the fourth quadrant of the unit circle. So you can get that value by subtracting it from 2\pi that is
2\pi-\frac{\pi}{4}=\frac{8\pi-\pi}{4}=\frac{7\pi}{4} because -pi/4 is the angle counted clockwise direction.
YOu know that it does not lie on the 3rd quadrant because tan(x) there is positive. There are other tricks too.
That's the "problem" with inverse trig functions--since, for example, there are an infinite number of solutions for y to the equation \tan{y} = x, in order for f(x) = \arctan{x} to be a well-defined function, you have to consider it as mapping to a particular interval of angles. Without qualification, arctan typically returns values between \frac{-\pi}{2} and \frac{\pi}{2}, but any interval of length \pi is valid as long as your usage is consistent. There are similar considerations for arcsin and arccos.
Edit: Because I'm not sure if I made it clear, let me say this: \arctan{x} is usually defined as the function from the real numbers to the interval (\frac{-\pi}{2} , \frac{\pi}{2}) such that \tan{(\arctan{x})} = x for any real x.
Oh I forget that arctan is an odd function. Thanks. But what if the question asks for a value for arctan(-1) within pi? I would have tried the 7pi/4 approach if I wasn't restricted to 0 to pi. Thanks.
If you have to find the value within an interval of a length \pi that doent mean that your interval must be [0,\pi] , moreover the common interval for this problem is chosen like JohnDuck stated [-\frac{\pi}{2},\frac{\pi}{2}].
This means that also <br /> \frac{7\pi}{2} is within that interval.
sutupidmath said:
One more thing arctan(-1) has no value that lies on the interval [0,\pi].
\frac{3\pi}{4}?
JohnDuck said:
\frac{3\pi}{4}?
Blahhhhhh! Yup.
