Similar matrix proof involving idempotency
9 replies · 4K views · last reply
jawhnay
Prove that if A is idempotent matrix of order n and B is similar to A, then B is idempotent
I was just wondering if my attempt at the solution right here is correct.
Given: A2=A and B=Q-1AQ
Attempt: B=Q-1QA B=IA B=A
Therefore, B=A^2 B=A(A) B=B(B) B=B2
No, not right. Matrices don't necessarily commute. You can't just change AQ into QA. Just work out (Q^(-1)AQ)^2.
The problem says that A is idempotent of order n, not 2.
You can't do this (switch the order of A and Q). Matrix multiplication is generally not commutative.
Start with B2 and show that it equals B.
For the real problem, you'll probably need to use induction.
If it says that B is similar to A, then am I allowed to assume A is similar to B a well?
I know how to do it, but I'm just wondering if I can assume that if I'm only given that B is similar to A.
Well, can you show that if B is similar to A then A is similar to B?
B=q-1aq
qb=q-1qaq
q-1bq=q-1qaq-1q
q-1bq=iia
q-1bq=a
the letters are not showing up in caps for some reason.
jawhnay said:
B=q-1aq
qb=q-1qaq
q-1bq=q-1qaq-1q
q-1bq=iia
q-1bq=a
I wouldn't worry about the caps. But you are juggling the order of the matrices around again to force things to work the way you want them to. They don't commute. Try that again without assuming the matrices commute.
jawhnay said:
B=q-1aq
qb=q-1qaq
You can't do this (above). On the left side of the equation, you multiplied on the left by Q, but on the right side of the equation, you multiplied on the right. When you multiply both sides of an equation by a matrix, you have to multiply both sides in the same way - either both sides on the left or both sides on the right.
jawhnay said:
q-1bq=q-1qaq-1q
q-1bq=iia
q-1bq=a
You probably hit your CAPS LOCK key.
