Simple Atomic Mass Unit question
The discussion revolves around calculating the energy released during the fission of the uranium isotope 235U when it captures a neutron, resulting in the production of 93Rb and 141Cs. The relevant nuclear masses are provided, and the energy release is determined by the mass difference before and after the reaction, using the equation E=Mc^2. It is clarified that the masses of the isotopes must be measured from a table, as they cannot be calculated directly. The inclusion of two neutrons in the reaction equation is explained by the need to balance the total nucleon number on both sides of the equation. Overall, the discussion emphasizes the importance of accurate mass values and the conservation of nucleons in nuclear reactions.
ZedCar
The uranium isotope 235U captures a neutron and undergoes fission to produce 93Rb and 141Cs. Calculate the energy released in this process.
The nuclear masses of the relevant isotopes are
235U 235.0439u,
93Rb 92.9217u,
141Cs 140.9195u
The answer is given as
n + 235U → 93Rb + 141Cs + 2n
LHS 235.0439 + 1.0087
RHS 92.921712 + 140.91949 + 2.10087
Difference is 0.1943u = 181 MeV
I realize the quantity of 1.0087 is the mass of neutron divided by one unified atomic mass unit. So that's (1.67493 x 10^-27) / (1.66 x 10^-27).
Also, the 2.10087 number is simply double this.
How have the 235.0439, 92.921712 & 140.91949 values been calculated? I know it's to do with E=Mc^2
Thank you.
It all has to do with the mass difference, (mass before) - (mass after) = (released) or (consumed energy). The values for the nuclei´s masses has to be taken from a table. There is no way of calculating the mass of a nuclei, it has to be measured.
Can it not be calculated from the part of the question which states;
235U 235.0439u,
93Rb 92.9217u,
141Cs 140.9195u
The difference in mass is what is relevant, ((Mass before)-(Mass after)).*c^2 = E. To calculate this you also need the mass of the neutron. The mass of the neutron can not be calculated and needs to be taken from a table. Also in order to get the mass in kilograms for the other nuclei you simply multiply it with the atomic mass unit, just as with the neutron.
In the answer, how is it known that 2n should be added? Why 2?
Take a look at the reaction - how many neutrons are produced?
Is it because the total nucleon number on both sides must equal. Since LHS=236 RHS can only equal this by adding 2n.
  • · Replies 22 ·
10K
  • · Replies 25 ·
