Simple Fraction Problem: Solving Addition and Subtraction with Whole Numbers
  • Thread starter Thread starter zak100
    Fraction
10 replies · 2K views
zak100
Hi,
I have the following question:
2 whole number ¼ - 1 whole number 2/3 ------(1)
1 whole number (1/4 -2/3)
I am getting –ve sign which is wrong.
However if I do:
2 whole number ¼ + 1 whole number 2/3
Then:
3whole number (1/4 * 3/3 + 2/3 * 4/4)
= 3 whole number(3/12 + 8/12)
= 3 whole number 11/12
How to solve (1) in the same way as I solved the addition question.
Zulfi.
zak100 said:
Hi,
What does this mean?
However if I do:
Then:
Zulfi.
I moved the thread to our homework section.
I'm making a guess: you want to calculate ##(2+\frac 1 4) - (1 + \frac 2 3 )##? Then ##(2+\frac 1 4) - (1 + \frac 2 3 ) = 1 + (\frac 1 4 - \frac 2 3)## is a valid step. The last bracket is negative, so what? Further simplification will probably include the "1+" there.
OKay. I got : 7/12.
Actually i forgot how i solved it which was giving negative answer. I would reply again.
Zulfi.
<<The last bracket is negative, so what?>>
Hi,
Thanks. Actually negative sign has significance. Its related to class 4 question. And in class 4 they learn 7-1 but not -7+1 which is -6. So negative has significance. I have to solve it in such a way that I should not get subtraction like : -7 + 1. However 7-1 is allowed. Book has that solution but at this point I don't have access to book.
Zulfi.
Hi,
I think its right for class 4 student. Actually they should avoid these questions. I remember studying about subtraction like 7-10 when i started studying algebra in class 6. Okay today i got that book & this is how they did to avoid subraction resulting in -ve numbers:
3⅓-1¾ = 2 + 1 +⅓-1¾=2+12/12 + 4/12 -1 whole number 9/12 = 1 whole number 7/12
Hope you would understand my text. Sorry i don't know latex. I typed it in word but can't paste here.
Actually they subtracted 3-1 which is 2. But they did not perform subtration of larger fraction 3/4 from smaller fraction 1/3 because it would result in a number with negative sign & they did not teach this in class 4.So Instead they added 1 & wrote the larger fraction with minus sign. Then later wrate 12/12 instead of 1 so that all denominators are same.
This is what i was asking.
Zulfi.
I think that arbitrary rule makes calculations more complicated than necessary.
Another approach would be to convert everything to x/12.
(3+1/3) - (1+3/4) = 40/12 - 21/12 = 19/12 = 1 + 7/12
(This is a readable way to write fractions without LaTeX, by the way)
This "whole number" business is very confusing, and was the reason your first post in this thread was so hard to comprehend. A mathematical expression should consist of numbers and operators, not words.
It would be better to write the above this way:
3⅓-1¾ = 2 + 1 +⅓-1¾=2+12/12 + 4/12 -1 - 9/12 = (2 - 1) + (16/12 - 9/12) = 1 + 7/12, or ##\frac{19}{12}##.
