*Simple frequency and period question - Thanks
3 replies · 3K views
nukeman
Ok, below is the question. I am having trouble with getting started. Like the first steps. A and B are the questions I am having trouble with.
"A 1.00 kg glider attached to a spring with a force constant of 25.0 N/m oscillates on a frictionless, horizontal air track. At t = 0, the glider is passing through its equilibrium position with a velocity vx = - 0.150 m/s. (The negative sign means that the glider is headed in the direction which will compress the spring.)
(a) Calculate the frequency and period of the glider’s motion.
(b) Calculate the amplitude of the simple harmonic motion. "
I just don't know how to get start with question A)
EDIT: This is from my notes
Frequency = 1/T
Where T = Period
Or Period = 1/f
Where f is Frequency
But I am not sure how to get the answer to A) for this question from that above data. ?
is this correct for period?
2*pi*sqrt( 1/25) = 1.25
so frequency would be 1 / 1.25 = .8?NOW, is this correct for B) amplitude:
KE = PE, so answer I got was when solving for x was: .03
You should have a formula for the period of a mass on a spring somewhere in your notes.
For time you may use time period of SHM
viz [itex]T = 2\pi \Large{\sqrt{\frac{m}{k}}}[/itex]
EDIT:
To find this, consider eqn for x coordinate of SHM, [itex]x=Asin(\omega t + \delta)[/itex]
This x repeats itself when sin repeats, ie, after 2π or time period T
[itex]sin(\omega t + \delta + 2\pi) = sin(\omega (t+T) + \delta)[/itex]
[itex](\omega t + \delta + 2\pi) = (\omega (t+T) + \delta)[/itex]
[itex]T = \Large{\frac{2\pi}{\omega}}[/itex] and in starting of this derivation we assume [itex]\omega = \Large{ \sqrt{\frac{k}{m}} }[/itex]
I am very lost on this. Is anything I did correct?
Any help would be fantastic to get me started. Thanks!
