Simple geometric series question
8 replies · 3K views · last reply
FeynmanFtw
Take the case for the mean:
[tex] \bar{x} = \frac{1}{N} \Big( \sum_{i=1}^Ni \Big)[/tex]
If we simply use the formula for the sum of a geometric series, we get
[itex]\bar{x} = \frac{N}{2} (2a + (N - 1)d)[/itex]
where a and d both equal 1, so we simply get the result
[itex]\bar{x} = \frac{1}{2} (N + 1)[/itex]
What I've been trying to do is to get the same result by being more rigorous, in that I've attempted to expand the series, i.e.
[tex] \bar{x} = \frac{1}{N} (1 + 2 + 3 + ... + N)[/tex]
and replace the terms with the appropriate expressions using N, for example 1 and 2 would be N-(N-1) and N-(N-2) respectively, and so forth. Unfortunately I just keep going round in circles and never achieve the correct result.
Am I wasting my time? Or have I simply not seen the next step?
The idea is to not replace all the terms, but only have the terms. For example ##2## gets replaced by ##N - (N - 2)##, but we don't want to replace the later term ##N-2##. The terms will cancel out then.
I think I understand, but just to be sure, could you clarify further please?
Clarify what? What is unclear about my explanation? Just take your sum ##1+2+3+...+N## and replace the first half of the terms in the way you indicated and leave the other half.
I'm still eagerly awaiting the question about a geometric series! :-p
Well I've already attempted what you've suggested, so it seems, though I cannot reach the final answer, as I've stated already.
I've tried going through the puzzle again and I sometimes obtain N/2 + 1, or N/2 as my final answer instead of (N+1)/2. I'm really confused as to where the +1 comes from. Somehow the final answer evades me.
The idea is to do this:
[tex]1+2+3+4+5 = (5-4) + (5-3) + 3 + 4 + 5 = (5-4) + 4 + (5-3) + 3 + 5 = 5 + 5 + 5= 15[/tex]
Well, as is usually the case, I left the problem yesterday evening and decided to sleep on it. This morning I woke up and solved it within a minute. Don't you just love it when you hit a wall and just jump over it the next time you look at a problem from a different angle?
Thanks to all who helped.
