Undergrad Spacetime Metric Topology: Does g Induce O?
  • Thread starter Thread starter nateHI
    Gr
The discussion centers on the relationship between a spacetime metric, denoted as g, and its induced topology, O. It questions whether stating that a set M has the metric topology is redundant when g is defined, particularly in cases where g is not positive-definite. Participants clarify that the metric tensor g does not define a metric in the conventional sense, as it takes two tangent vectors rather than points. They emphasize that the topology of M is independent of g and arises from the Euclidean topology of R^4 via coordinate charts. The conversation highlights the distinction between pseudo-Riemannian metrics and true metrics in the context of topology and differentiability.
nateHI
Is it fair to say, when talking about spacetime with a given metric, it would be redundant to state that the associated set has the metric topology placed on it. In other words, let ##M## be a set, ##O## the metric topology, ##\nabla## a connection, ##g## a metric, and ##T## be the direction of time, then
##(M,O,\nabla,g,T)=(M,\nabla,g,T)##
Edit: I suppose what I'm asking is, does the metric ##g## induce the metric topology?
What is "the metric topology" when ##g## is not positive-definite?
You're right, I suppose I should make that precise. The metric topology I'm referring to has as open sets
##B_r(m_0)=\{m_0\in M : g(m_0,m)<r\ \forall m\in M \text{ where } r>0\}##
I am sorry, but I still do not understand. The "metric" ##g## (i.e., not a metric in the sense of metric spaces) takes as input two tangent vectors at the same point of the manifold, not two points of the manifold.
I'm referring to ##g## in two different contexts which is what I think made my question unclear. So, let ##g## be the metric from GR and let ##d## be the metric from math class. Does defining ##g## on a differentiable manifold automatically induce ##d##?
As an aside, this is interesting to me since I believe it to be key in the notion of a topological field theory. Of course I'm just starting on the subject so I could be wrong.
The balls you refer to are not very good to use to build a topology when you have a pseudo Riemannian metric. You may want to use a topology based on the intersection of light cones instead.
Likes QuantumQuest
As I understand it, the topology of ##M## is independent of ##g##. It arises from the Euclidean topology of ##\mathbb{R}^4## mapped onto ##M## via the coordinate charts. You need the topology in order to define concepts such as "smooth" and "differentiable".
The metric tensor ##g## doesn't define a "metric" in the "metric space" sense because it isn't positive definite.
OK, I think I get it now. Thanks everyone!
The metric tensor ##g## doesn't define a "rmetric" in the "metric space" sense because it isn't positive definite.
That's why it's better to talk about pseudo-Riemannian manifolds and pseudo-metric to make this clear from the very beginning. Analysis is based on a true metric not a pseudo-metric.
As far as I understand it a given metric in general relativity could be valid for more than one topology.
  • · Replies 25 ·
  • · Replies 39 ·
  • · Replies 50 ·
  • · Replies 25 ·
