Simple Static Pressure problem, with units
5 replies · 3K views
hackashack
Hi I'm having trouble solving this physics problem if anyone can help it would be greatly appreciated !
Static pressure problem: A bathtub contains water to a depth of 20 inches. Determine the pressure at the bottom of the bathtub in both [psia] and [psig] (a being absolute pressure and g being gauge pressure)
im using P=pgh
what I've tried doing was to find gauge pressure first: P=pgh=(1.94slug/ft^3)(32.2ft/s^2)(1.67ft). I got the 1.67 feet from converting 20 inches to feet. the answer i get is 104.11slug/s^2 but they want it in psi or lb/in^2 and i am having trouble converting these units =[
Why don't you just convert the initial 20 inches to meters then solve for the standard SI units?
Well the problem is that i don't know how to get rid of the /s^2 in my final answer and even if i use the standard SI units ill still come up with an answer that has /s^2
Also…
look at the definition of what a pound actually is (in terms of units). That should fix things.
Instead of using different unit systems, 1 cu. ft. of fresh water weighs about 62.4 pounds. Knowing that number, you should be able to find psi given the depth of water in the bath tub.
