Simple topology problem involving continuity
The discussion focuses on demonstrating the continuity and closed nature of a specific map p as presented in James Munkres' "Topology" (2nd Edition). Participants clarify that to prove continuity, one can utilize the epsilon-delta definition, particularly when dealing with maps between metric spaces, rather than relying solely on open sets. For establishing that p is a closed map, the discussion emphasizes the necessity of working with closed sets and references theorems that facilitate this proof. The insights provided by forum members HallsofIvy and micromass were instrumental in addressing these concerns.
  • Understanding of continuity in topology as defined by Munkres
  • Familiarity with the epsilon-delta definition of continuity
  • Knowledge of closed sets and closed maps in topology
  • Basic concepts of metric spaces
  • Study the epsilon-delta definition of continuity in detail
  • Explore theorems related to closed maps in topology
  • Review examples of continuous and closed maps in metric spaces
  • Examine the implications of continuity and closedness in topological spaces
Students of topology, mathematics educators, and anyone seeking to deepen their understanding of continuity and closed maps in topological spaces.
Math Amateur
MHB
Example 1 in James Munkres' book, Topology (2nd Edition) reads as follows:
Munkres states that the map p is 'readily seen' to be surjective, continuous and closed.
My problem is with showing (rigorously) that it is indeed true that the map p is continuous and closed.
Regarding the continuity of a function Munkres says the following on page 102:
Let X and Y be topological spaces. A function f \ : \ X \to Y is said to be continuous if for each open subset V of Y, the set f^{-1} (V) is an open subset of X.
Yes ... fine ... but how do we use such a definition to prove or demonstrate the continuity of p in the example?
Can someone show me how we use the definition (or some theorems) in practice to demonstrate/ensure continuity?
I have a similar issue with showing p to be a closed map.
On page 137 Munkres writes the following:
A map p "is said to be a closed map if for each closed set A of X the set p(A) is closed in Y"
Again, I understand the definition, I think, but how do we use it to indeed demonstrate/prove the closed nature of the particular map p in Munkres example?
Hope someone can help clarify the above issues?
Peter
Okay, suppose U is open in [0, 2]. We want to show that f^{-1}(U) is an open set in [0, 1]\cup [2, 3].
Define A= f^{-1}(U)\cap [0, 1] and B= f^{-1}\cap [2, 3]. If both A and B are open then their union, f^{-1}(U) is open.
So we need to show that A and B are open. Let y be in U. Then either y= 1 or y= 0, or y= 2, or y is in (0, 1), or y is in (1, 2].
1) if y= 1, y= 1= f(1)= f(2)
2) if y= 0, y= 0= f(0)
3) if y= 2, y= 2= f(3)
Those are "endpoints" of intervals so any open set about them is of the form [0, x) or [x, 1) in [0, 1] or [x, 2) in [1, 2].
2) if y in (0, 1) then there exist x in (0, 1) such that f(x)= x= y.
3) if y in (1, 3) then there exist x in (2, 3) such that f(x)= x- 1= y.
Likes 1 person
In this case, you can check continuity like you did in analysis: with epsilon-delta definitions.
So in topology, if you encounter a map between metric spaces, you can just check the epsilon-delta definition of continuity. You don't need to work with open sets here. In fact, I think it's better to always avoid the open set definition whenever it is possible.
So if you know continuity from analysis well, then you should have no problems with the topological definition.
Closedness of maps is a different issue. There you indeed need to work with the closed sets. Luckily, there are some nice theorems which allow us to conclude that a map is closed. In fact, closedness as a concept is important because we care about these theorems. It's not like it's of independent interest, like continuity.
Likes 1 person
Thanks HallsofIvy and micromass ... your posts were extremely helpful
Peter
  • · Replies 43 ·
