Simple Trig Limit: Evaluate lim x->0 of (1-cos4x)/9x^2
  • Thread starter Thread starter L4N0
    Cos Limit Trig
The limit lim x->0 of (1-cos4x)/9x^2 is evaluated as 8/9, despite initially appearing undefined due to the 0/0 form. The discussion suggests using trigonometric identities, specifically the double angle formula, to simplify the expression. L'Hopital's rule and power series expansions were mentioned but not covered in the current chapter. The problem emphasizes the importance of recognizing the correct limit laws and manipulation techniques in calculus. Ultimately, the solution was reached successfully by applying the suggested trigonometric approach.
L4N0
Evaluate the limits that exist:
lim x->0 of \frac{1-cos4x}{9x^{2}}
lim x->0 \frac{1-cosax}{ax} = 0
so far I've got this
\frac{4x}{9x^{2}}\frac{1-cos4x}{4x}
The second part has a limit of 0 but I don't know what to do about the first fraction. To me it looks undefined but according to some java applet I found on the internet the limit should be 8/9. What's the right answer?
The limit has the form 0/0. That suggests you use L'Hopital's rule. Alternatively, if you know the power series expansion of cos(x)=1-x^2/2!+x^4/3!-..., you could substitute x->4x and use that.
Thank you. So far we are in Ch 2. so we haven't done L'Hopital's rule or power series. I guess saying it is undefined is enough for now.
The trouble with that is that is IS defined. If you can't use those, then you have to use tricks. Try a double angle formula like cos(2x)=1-2*sin(x)^2. Use that to express cos(4x). Then use lim x->0 sin(ax)/(ax)=1. I'm guessing you do know that from the relevant equation you posted.
oops, I got confused a bit...
Anyways, I used your suggestion and solved it.
Thanks again.
Thanks again.
Very sneaky little problem: the limit law it looks the most obvious to use is the wrong one!. Keep these kinds of manipulations in mind on exam problems...
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
13K
  • · Replies 19 ·
  • · Replies 18 ·
