Probability of All Urns Having At Least One Ball | Simple Urn Problem
  • Context: Undergrad
  • Thread starter Thread starter JolleJ
The discussion focuses on calculating the probability that all k urns receive at least one ball when M balls are distributed uniformly at random among them, with M being greater than k. The key formula derived is P(k, M) = (M-1 choose k-1) / (M+k-1 choose k-1), which represents the probability that each urn contains at least one ball. The conversation also references the Coupon Collector's Problem as a related concept, emphasizing that as M approaches infinity, the probability of each urn containing at least one ball approaches 1.
  • Understanding of basic probability theory
  • Familiarity with combinatorial mathematics, specifically binomial coefficients
  • Knowledge of the Coupon Collector's Problem
  • Ability to solve recurrence relations
  • Study the Coupon Collector's Problem in detail to understand its implications in probability theory
  • Learn about binomial distributions and their applications in combinatorial problems
  • Explore recurrence relations and their solutions in probability contexts
  • Investigate the concept of expected values in probability distributions
Mathematicians, statisticians, and students studying probability theory, particularly those interested in combinatorial problems and their applications in real-world scenarios.
JolleJ
You have k urns and M (M>k) balls.
Each ball is placed in a random urn (w/ uniform distrubution).
What is the probability that every urn has at least one ball in it after the M balls are placed?
What is the probability that a given urn will receive no balls?
That's not really the right approach because the urns are not independent and the OP is asking a question not about a given urn but about ALL the urns.
Let pi(n) be the probability to have i empty urns at time n.
pi(n+1) = pi(n)(k-i)/k + pi+1(n)(i+1)/k
The initial condition is
pi(1) = δk-1
Seems like you have to solve this recurrence.
EDIT: Err this was wrong
Maybe this will work better
p0(M) = 1 - p1(M) - p2(M) - ... - pk-1(M)
= 1 - (k-M)((k choose 1) * (k-1)M + ( k choose 2) * (k-2)M + ... +(k choose k-1)1M)
I know, I know, that was not supposed to be the complete answer. But you can build up from there. Following my route I get
\sum\limits_{n=1}^{k-1} (-1)^{n+1} \left(1-\frac{n}{k}\right)^M \left(\begin{array}{c}k\\n\end{array}\right)
Kai, what do you get?
I got
1 - \sum_{i=1}^{k-1} \left(<br /> \begin{array}{c}<br /> k \\<br /> i \\<br /> \end{array}<br /> \right) \left(\frac{k-i}{k}\right)^M
Applying your formula to just the case k = 3 , we get
3(2/3)M - 3(1/3)M ≈ 3 (2 M )/(3 M )
But above doesn't go to 1. The probability that every urn has a ball must clearly go to 1 if you keep adding more and more balls.
I been thinking sort of down the roads of what you're doing...
@Kai: Your suggestion gives negative results for m=100, k=50...
Hmm, yeah I see my problem. I'm trying to condition on there being a specific number of empty urns, but I'm calculating the probability to have more than or equal to that many.
The event whose probability is required is opposite to the event:
After M independent, equally probable fillings of k urns, there is at least one (meaning either one, or two, ... , or k) being empty.
What is the probability p_l of exactly l urns remaining empty? (How many M letter words can be made with k distimct letters, and how many with k-l letters if you could repeat the letters and their order matters?)
Yes, but I am not having an easier time calculating this.
Knowing this would obviously solve my problem; but this is an even harder question. Harder in the sense that my need (l = 0) is a subproblem.
Label the urns from 1 to k. Then, each placement of the balls is equivalent to an M-letter word with the "letters" 1, 2, ..., k. Each of these k^M words is equally probable.
Let x(k, M) be the number of M letter words in which each of the k letters of the alphabet occurs at least once.
We can divide this set into two disjoint subsets: A set in which 1 enters exactly once and in which it occurs more than once. The first subset has x(k - 1, M - 1) elements. The second x(k, M - 1). Therefore, we have the recursion:
<br /> x(k, M) = x(k - 1, M - 1) + x(k, M - 1)<br />
Obviously, x(k, M) = 0, \ k &gt; M.
From here, we deduce that:
<br /> x(k, k) = x(k - 1, k - 1) = \mathrm{const}.<br />
This constant is obviously equal to 1, since there is only one way of filling k urns with k balls (by placing exactly one ball in each urn).
Then, we have:
<br /> x(k, k + 1) = x(k - 1, k) + 1 \Rightarrow x(k, k + 1) = x(1, 2) + k - 1, \ k \ge 1<br />
Obviously, x(1, M) = 1, M \ge 1. This boundaty condition is consistent with the above recursion relation if and only if x(0, M) = 0, M \ge 0.
To reduce the recursion w.r.t. k, we perform a discrete Laplace transform w.r.t. k:
<br /> X_M(s) \equiv = \sum_{k = 0}^{\infty}{x(k, M) e^{-k \, s}}<br />
Multiply the recursion by e^{-(k - 1)s} and sum w.r.t. k from 1 to ∞, to get:
<br /> e^{s} \, \left[ X_M(s) - x(0, M) \right] = X_{M - 1}(s) + e^{s} \, \left[ X_{M - 1}(s) - x(0, M - 1) \right], \ M &gt; 1<br />
<br /> X_{M + 1}(s) = (1 + e^{-s}) X_{M}(s), \ M \ge 1<br />
This recursion w.r.t. M is a geometric sequence with an easy solution:
<br /> X_M(s) = X_1(s) \, (1 + e^{-s})^{M - 1}, \ M \ge 1<br />
<br /> X_1(s) = \sum_{k = 0}^{\infty}{x(k, 1) \, e^{-k s}} = x(0, 1) + x(1, 1) e^{-s} = e^{-s}<br />
Then, take z \equiv e^{s}, and we have:
<br /> \tilde{X}_M(z) = X_M(s) = \frac{1}{z} \, \left(1 + \frac{1}{z} \right)^{M - 1}, \ M \ge 1<br />
Then, if you expand this binomial into a Laurent series near z = 0, you can identify the coefficients as x(k, M). We have:
<br /> \tilde{X}_M(z) = \frac{1}{z} \, \sum_{k = 0}^{M - 1}{\left( \begin{array}{c} M - 1 \\ k \end{array}\right) \, \frac{1}{z^k}} = \sum_{k = 1}^{M}{\left( \begin{array}{c} M - 1 \\ k - 1 \end{array}\right) \, \frac{1}{z^k}} \Rightarrow x(0, M) = 0, x(k, M) = \left( \begin{array}{c} M - 1 \\ k - 1 \end{array}\right), 1 \le k \le M, x(k, M) = 0, k &gt; M<br />
So, I think the answer is:
<br /> P(k, M) = \left( \begin{array}{c} M - 1 \\ k - 1 \end{array}\right) \, \frac{1}{k^M}<br />
The OP defined M>k, but I prefer n=M, n>k as more standard notation for the binomial distribution.
Then we have n events with 1/k probability. The binomial distribution will have a non zero probability for zero events for any value of n given P=1/k. An event is a ball in an urn. The mean (expected) value would be n/k assuming all balls go into an urn.
EDIT: The probability that every urn has at least one ball should be 1-P(x=0). So for 20 balls and 10 urns P(x=0) = 0.1216 and 1-0.1216= 0.8784
This is just a standard exercise from enumerative combinatorics.
Label the urns 1 through k. How many ways can we place the M balls in the k urns so that each urn gets a ball? Line up the balls and urns in a straight line, with lower-labeled urns to the left of higher-labeled urns and with the leftmost object being a ball, the rightmost object being an urn, and no two urns adjacent. Put all balls to the left of urn 1 into urn 1, then put all remaining balls to the left of the urn 2 into urn 2, and repeat until each ball is in an urn. There are M-1 choose k-1 ways to place the urns, since k-1 of the M-1 distinct spots between balls must be chosen for urns 1 through k-1, with urn k going on the very end.
Now how many total ways are there to put the balls in the urns? We repeat the process above, except we take away the requirements that the leftmost object be a ball (so that urn 1 can be empty) and that urns cannot be adjacent (so that for j>1 urn j can be made empty by putting it directly after urn j-1). We still need urn k to go last since otherwise we would not have placed every ball into an urn. There are M+k-1 choose k-1 ways to place the urns now, since urn k must be placed last, and before it are M+k-1 spots on which to place objects, exactly k-1 of which must be occupied by urns.
Thus the probability each urn contains a ball is (M-1 choose k-1)/(M+k-1 choose k-1).
Thanks JCVD, that explanation is very clear.
Well spotted. I was trying to calculate the opposite probability, that there is at least one empty urn. But even that I got wrong.
I got P= 0.8784 for n(M)=20, k=10 using the binomial distribution. Does anyone want the check JCVD's solution against this for these values?
Thank you very much JCVD ! What a great way to do it.
Why? Is there an upper limit on the number of balls that an urn can hold? If so, what is it (other than n itself)? In principle, there is no mathematical reason that the probability should equal 1 for any finite number of balls, although the probability can get arbitrarily close to one. This seems to be a fairly straightforward problem involving the binomial distribution. All one has to do is show that there is a non zero probability that exactly one urn may be empty after any finite n. Then the probability that all all urns have at least one ball is 1-p(x=0). It's not necessary to calculate the probability that at least one urn is empty after n balls. It should be clear that for n balls and k urns, the expected value for the number of balls in each urn is n/k which is the expectation of the binomial distribution when p=1/k.
Pick anyone urn, which is empty at the start.
For each throw there is a 1/k chance that a ball will end up in this urn. So with each additional turn, the chance that the urn remains empty becomes smaller (1/k^M after M turns).
For an infinite number of throws that probability will go to zero. If for each individual urn the probability to remain empty is zero, then the probability of finding at least one empty bowl in the set is also zero.
In other words the probability that there is at least one ball in each urn increases with M and the limit M->infinity will be 100%.
Kai performed a simple sanity check on my formula and noted that it goes the wrong way. Therefore it has to be wrong. Well spotted, as I said.
Your formula may have been incorrect, but your initial intuition that finding the probability that exactly one urn will be empty for any n was a correct approach. Note "at least one" is a higher probability than "exactly". The former would underestimate the probability that every urn gets at least one ball when computing 1-p(x=0). And of course, we are dealing with a finite mathematics problem here.
