Simplifying |1+e^{ik Δ cos θ}|² + |e^{ik Δ sin θ}|²
8 replies · 2K views
mmpstudent
I have an EM problem (michelson interferometerish) where I have a term that I need to reduce. It is
[tex]|1+e^{ik \Delta cos\theta}|^{2}+| e^{ik \Delta sin\theta}|^{2}[/tex]
I have foiled it and squared the last term but is there something that I am missing. I am multiplying it by a large matrix and hope that it reduces to something simple.
Thanks in advance
Are 'k' and 'Δcos(θ)' always real and positive? If so, it simplifies a fair bit. First of all, the second term is easy: it's just 1. The magnitude of a complex exponential is unity.
Similarly, the first term can be simplified a lot by applying the Euler relation for complex exponentials.
k I'll review that material. I should have said that k is a 4 vectore driven at a frequency in the z direction
Really? k is a 4-vector? Like, in the relativistic sense?
I would have thought that k would be the wavevector (an ordinary 3-vector) and k would be its magnitude, which is the wavenumber 2pi/lambda.
i understand that the second term is 1
but my attempt at reducing the first term
[tex]|1+e^{ik \Delta cos\theta}|=|(1+cos(k \Delta cos\theta))+i sin(k \Delta cos\theta)|[/tex]
[tex]\sqrt{(1+cos(k \Delta cos\theta))^{2}+sin^{2}(k \Delta cos\theta)}[/tex]
[tex]=\sqrt{2+2cos(k \Delta cos\theta)}[/tex]
in which I'm stuck
in which I'm stuck
It's squared. So you can get rid of the square root. Then you can add 1 to that. Isn't that much simpler?
yeah I guess, but i was hoping to be able to take it back into a form that would have exponentials again. I wonder if me dropping the complex conjugate terms in the prior steps be the reason why its not simplifying the way I want it to. I will try with them included i guess
You mean complex exponentials? I don't see why you want this, since the magnitude of those two complex numbers obviously gives you a real number, which would seem more desirable. BUT, if you really insist, I suppose you could always express the cosine term in terms of complex exponentials. You know how to do that, right?
What complex conjugate terms?
I forgot I didn't post the whole problem in the beginning. Disregard the complex conjugate part. This might be helpful need to chug thru this now. Thanks
