Simplifying (√6/√7) × √21
5 replies · 3K views
Comscistudent
Hi I'm trying to give myself a refresher in Leaving Cert maths and I'm running through some problems. Here's one which has me stumped (sorry I can't figure out how to show the actual symbols on the post, it's just showing as raw LaTEX when I try )
Combine terms and simplify the expression of -
(sqrt6/sqrt7) * sqrt21
The actual answer is that you move the /sqrt7 to the sqrt21 to end up with sqrt6 * sqrt3 = 2sqrt3
I missed this and instead multiplied the right hand term by sqrt7/sqrt7 but my answer is different. Can someone explain why my logic is incorrect?
(sqrt6/sqrt7) * ( (sqrt21*sqrt7)/sqrt7 )
sqrt6/sqrt7 * sqrt147/sqrt7
sqrt882/sqrt7
3sqrt14
Mathematics news on Phys.org
Hi TubeAlloy and welcome to MHB! :D
$$\dfrac{\sqrt6}{\sqrt7}\cdot\sqrt{21}=\sqrt{18}=3\sqrt2$$
sqrt882/sqrt7
3sqrt14
Your logic is fine but you've made an error in your calculation. Can you spot it?
Quote this post to see how I coded the $\LaTeX$.
Oh wow I feel so silly, thanks a million for the help once I knew I wasn't doing something wrong I was able to spot the error.
$$\dfrac{\sqrt6}{\sqrt7}\cdot\dfrac{\sqrt147}{\sqrt7}$$
This is $$\dfrac{\sqrt882}{\sqrt49}$$ not $$\dfrac{\sqrt882}{\sqrt7}$$ as I had thought
So then it's $$\sqrt18$$ == $$3\sqrt2$$
Good work!
To get all of the numbers in a radical under the square root sign use \sqrt{123}. Note the curly braces. :)
TubeAlloy said:
Combine terms and simplify the expression: [tex]\frac{\sqrt{6}}{\sqrt{7}}\cdot\sqrt{21}[/tex]
I missed this and instead multiplied the right hand term by sqrt7/sqrt7 . Why?
sqrt882/sqrt7
3sqrt14
Did some teacher tell you, "To simplify radicals,
introduce more radicals into the expression" ?
Here is the recommended way to simplify it:
. . [tex]\begin{array}{ccc}<br /> \dfrac{\sqrt{6}}{\sqrt{7}}\cdot\sqrt{21} &=& \sqrt{6}\cdot\dfrac{\sqrt{21}}{\sqrt{7}} \\ <br /> &= & \sqrt{6}\cdot\sqrt{\dfrac{21}{7}} \\ <br /> & = & \sqrt6\cdot\sqrt{3} \\<br /> & = & \sqrt{18} \\<br /> &=& \sqrt{9\cdot2} \\<br /> &=& \sqrt{9}\cdot\sqrt{2} \\<br /> &=& 3\sqrt{2} \end{array}[/tex]
soroban has made an excellent point: the simpler the better! It's good to see experimentation with other methods though, and I think it's good that the error was spotted. Sometimes the simpler approach is not always realized so it's a good thing to be able to adapt one's skill set to the problem at hand. But at the end of the day, I think striving for simplicity is the best approach.
