Simplifying Boolean algebra expression with five terms
4 replies · 3K views
Caponae
Here's the problem:
a'b'c'd' + a'b'cd' + a'b'cd + ab'c'd' + abc'd'
I've gotten it down to:
ac'd' + b'c'd' + a'b'c
Having trouble coming up with a way to simplify it more...Is this as far as it can go?
Any help appreciated, thanks...
I did a quick K-map, and got it down to 3 terms, but my terms are different from yours. I got 2 3-terms and one 4-term.
Did you use a Karnaugh map? Where did the ac'd' term come from, for example?
I used Boolean Algebra Axioms that I had learned in college to simplify it to the result that I got...
The lines are on the board at work, I'll try to update this thread with them tomorrow from work...
Thanks for the response...
I found an error in my quick K-map. I now get the same answer as you. For problems like this with up to 4 inputs, the K-map is the easiest way to see what the simplest answer is. Well, assuming you don't make an error like I did yesterday :blushing:
no problem...it happens...thanks for the update...i feel confident about the math, i just wanted it smaller to help out in a query that i was writing...
