Simplifying [(m^3)(n^-3)]^-1 / (m^-5n)
  • Thread starter Thread starter runicle
23 replies · 5K views
runicle
I have the equation [(m^3)(n^-3)]^-1 over m^-5n
So far i got 1 over m^6n^6 divide by m^-5n...
Is it right or no?
I've moved this from the Tutorials Forum into the Homework Help section.
That's not an equation, it's an expression.
Is it right or no?
No, it isn't. What steps did you take to manipulate the numerator of your original expression?
First off i went to the basics I multiplied (m^3)(n^-2) and got m^6n^6
Then i inversed it to get 1 over m^6n^6, so i can divide that with m^-5. Yet, i still don't know arithmetic.
That's not right. You should be using the following rule:
[tex](x^ay^b)^c=x^{ac}y^{bc},[/tex]
which should be in your textbook.
What are you trying to do? Simplify the expression?
Note that [itex]m^3 \cdot n^{-3}[/itex] does not equal [itex]m^6 n^6[/itex].
Where did the extra powers of m come from? Where did the negative powers of n go?
- Warren
runicle said:
So the exponent doesn't affect the base number
No. There is no "base number" here anyway -- just the variables m and n.
- Warren
Okay wait what happens to the exponents when its (m^3)(n^2)
Did you see what Hurkyl posted? The general rule of "exponent distribution:"
[tex](x^ay^b)^c=x^{ac}y^{bc}[/tex]
You have an example of this here:
[tex](m^3 n^{-3})^{-1} = m^{3 \cdot -1}n^{-3 \cdot -1} = m^{-3} n^{3}[/tex]
Again, I'll ask you: what are you trying to do? Simplify the expression?
- Warren
Nothing at all "happens" to the exponents -- the bases are different, and thus they are completely unrelated to each other.
- Warren
No. Now you're getting me a bit confused. First you told us the problem was this:
and now you're talking about (m^3)(n^2). Which is it?
Please repeat the problem, taking care to type it exactly as shown in your homework. Also, please tell us exactly what you're trying to do: are you just supposed to simplify the expression?
- Warren
- Warren
Nevermind i got it I'm simplifying it It's n^2m^5 over m^3n
The question was simplify [(m^3)(n^-3)]^-1 over m^-5n
I got another question I have to factor 3x^2 -13x-10
So far i get this far
3x^2 -13x-10
3x^2+2x-15x-10
x(3x+2)-5(3x+2)
What do i do next...
I'm afraid that
[itex]\frac{(m^3 n^{-3})^{-1}}{m^{-5n}}[/itex]
does not simplify to
[itex]\frac{n^2 m^5}{m^{3n}}[/itex]
- Warren
Let's do this in steps.
First, simplify the numerator of
The -1 exponent "distributes", multiplying the exponents on m and n:
[itex](m^3 n^{-3})^{-1} = m^{-3}n^3}[/itex]
So the entire expression becomes:
[itex]\frac{m^{-3}n^3}{m^{-5n}}[/itex]
Now, factors with negative exponents can be "flipped" across the division line, as can be seen by multiplying both sides by the same factor with the exponent positive rather than negative:
[itex]\frac{m^{-3}n^3}{m^{-5n}} = m^{-3}n^3 m^{5n}[/itex]
One negative-exponent factor went up, while the other negative-exponent factor I left alone.
Finally, multiplyiing two factors (with the same base) is the same as adding their exponents:
[itex]n^3 m^{5n - 3}[/itex]
If you do not understand any step of this, please let me know.
- Warren
3x^2 -13x-10
3x^2+2x-15x-10
x(3x+2)-5(3x+2)
Your final answer will be:
0 = (x - 5)(3x + 2)
You should see that multiplying (3x + 2) by x and then adding that to -5(3x + 2) is the same as just multiplying by (x - 5).
I find it easiest to make a punett square if I can't figure it out in my head. If you can't figure it out using a punett square, then try using the quadratic formula; I try and stay away from that though because it can be messy.
0 = (x - 5)(3x + 2)
No it isn't. It's an expression that need to be factored, not an equation!
I know what I'm doing... I always mix up the terms equation and expression. I know now 2^-3 is the same thing as 1 over 2^3 so now you can understand how i did it
Whoa! I must have read that too quickly. Sorry if I misled you runicle.
