Simplifying ∫sin(2x)tan⁻¹(sin(x))dx
  • Thread starter Thread starter c.dube
    Integral
7 replies · 2K views
c.dube
OK, so I'm just trying to refresh my calc knowledge before I go off to school. The problem I'm trying to do is:
[itex]\int sin(2x)tan^{-1}(sin(x))dx[/itex]
So what I've done is, first, replace sin(2x), giving:
[itex]\int 2cos(x)sin(x)tan^{-1}(sin(x))dx[/itex]
or
[itex]2\int cos(x)sin(x)tan^{-1}(sin(x))dx[/itex]
Then, I assume that sin(x) = u (and therefore, du = cos(x)dx). This gives me:
[itex]2\int utan^{-1}(u)du[/itex]
Then, I integrate by parts.
[itex]2\int utan^{-1}(u)du = 2(\frac{1}{2}u^{2}tan^{-1}(u)-\int \frac{u^{2}}{2+2u^{2}})[/itex]
or
[itex]2(\frac{1}{2}u^{2}tan^{-1}(u)-(\frac{u^{3}}{6}+\frac{u}{2}))[/itex]
Substituting back in for u gives me:
[itex]2(\frac{1}{2}sin^{2}(x)tan^{-1}(sin(x))-(\frac{sin^{3}(x)}{6}+\frac{sin(x)}{2}))[/itex]
Or, to simplify a little:
[itex]-\frac{sin^{3}(x)}{3}+tan^{-1}(sin(x))sin^{2}(x)-sin(x)[/itex]
My question is where do I go from here to simplify, and also if the work I've done up to this point is correct/on the right track (it's been a while since I took calc so go easy hahah). Just so you all know, I don't have an answer key for this problem so I'm working off of Wolfram Alpha's answer which is:
[itex]\frac{1}{2}((cos(2x)-3)(-tan^{-1}(sin(x)))-2sin(x)) + C[/itex]
Thanks in advance!
or
There's an error from the integral on the right side of the top equation going to the line below it. Factor out a 2 from the denominator then try long division to make the integrand into something easier to integrate.
Ahh I knew it was something really dumb like that! Thanks, but new question now. For the long division, what answer should I be getting? Because trying to work it through I'm not getting the right answer. I get an answer of [itex]1-\frac{1}{u}[/itex] and the remainder but I can't get the remainder (unless its [itex]\frac{1}{u^{3}+u}[/itex]). The math doesn't seem to work when I check this can you help me out? Polynomial long division was always a weakness.
Whoops never mind I got it ([itex]1-\frac{1}{u^{2}+1}[/itex]) dumb mistake.
You can read about polynomial long division here
http://www.sosmath.com/algebra/factor/fac01/fac01.html"
But if I can avoid it, I try not to use it...
For problems like this, there's a trick so you don't have to use long division:[tex]\frac{u^2}{u^2 + 1} = \frac{u^2 + 1 - 1}{u^2 + 1} = \frac{u^2 + 1}{u^2 + 1} - \frac{1}{u^2 + 1} = 1 - \frac{1}{u^2 + 1}[/tex]
OK so now I have:
[itex]2(\frac{1}{2}u^{2}tan^{-1}(u)-\frac{1}{2}(u-tan^{-1}(u))[/itex]
Or:
[itex](u^{2}+1)tan^{-1}(u)-u[/itex]
From here, I substitute sin(x) back in:
[itex](sin^{2}(x)+1)tan^{-1}(sin(x))-sin(x)[/itex]
Can I simplify more or am I still making a mistake? Thanks for all the help.
It's correct and probably as simplified as you can make it; just remember the + c :wink:
Hahah yes that darn + C :smile: Thanks for all your help!
