Simplifying three trig expressions with tan, cot, and csc
17 replies · 4K views · last reply
Cosmic-Kat
I have re-post this forum as I should have paid closer attention to rules. I apologized for that.
1) The expression tan^3 θ + sinθ/cosθ is equal to:
(a) cot θ (b) tan θ sec^2 θ (c) tan θ (d) sin θ tan θ (e) tan θ csc^2 θ 2) Simplify (cos θ/1+ sin θ - cosθ/sinθ-1)^-1
(a) cos θ/2 (b) 2sec θ (c) 2sin θ (d) csc θ/2 3) The expression cot θ/csc θ-sin θ is equal to:
(a) cos θ (b) sec θ (c) tan θ (d) sin θ (e) csc
:[/B]
Identifying the trigonometry identities
Tan=sin/cos
Sec=1/cos
Cot= cos/sin
Csc= 1/Sin
:[/B]Here's my attempt on the first question:
Tan^3 = Sin^3/Cos^3;
Sin^3/Cos^3 + Sin/Cos=
Sin^4/Cos^4 = Tan
(c) Tan
The second question (I'm very lost on this) :
(2Cos/(1+Sin)(Sin-1))^-1=
(2Cos(Sin-1)/(1+Sin))^-1=
(-2Cos/1)^-1=
1/2cos= 2sec
(b) 2Sec
The third question:
(Cos/Sin)/ (1/Sin) -(Sin/1) =
(Cos/Sin)(Sin/1)/ (1/Sin)=
(Cos*Sin/Sin)/(1/Sin)=
Cos/(1/Sin) =
Sin/Cos = Tan
(c) Tan
It's not clear what the questions are.
For 1) is it ##\tan^3(\theta) + \frac{\sin(\theta)}{\cos(\theta)}## or is it ##\frac{\tan^3(\theta) + \sin(\theta)}{\cos(\theta)}##?
What you wrote is the first, although you might have meant the second. When you write fractions using inline text, you have to use parentheses around the entire numerator or denominator (or both), whenever there are two or more terms.
For 2) I can't even guess what you mean.
For 3) what you wrote is ##\frac{\cot(\theta)}{\csc(\theta)} - \sin(\theta)##. Did you mean ##\frac{\cot(\theta)}{\csc(\theta) - \sin(\theta)}##? If so, write it as cot(θ)/(csc(θ) - sin(θ)).
Cosmic-Kat said:
:[/B]
Tan=sin/cos
Sec=1/cos
Cot= cos/sin
Csc= 1/Sin
Sin^4/Cos^4 = Tan
(c) Tan
(-2Cos/1)^-1=
1/2cos= 2sec
(b) 2Sec
The third question:
Cos/(1/Sin) =
Sin/Cos = Tan
(c) Tan
:[/B]
Tan=sin/cos
Sec=1/cos
Cot= cos/sin
Csc= 1/Sin
Sin^4/Cos^4 = Tan
(c) Tan
[/B]
Hello Cosmic-Kat. Welcome to PF!
You have committed two huge algebra/trig errors.
Review how to add rational expressions (fractions).
Sin4(θ)/Cos4(θ) = (Sin(θ)/Cos(θ))4 ≠ Tan(θ)
Sin^4/Cos^4 = Tan
(c) Tan
This is the problem that Sammy said had two errors. For this problem it's better to write things in terms of ##\tan(\theta)##.
I am sorry about the confusion.
I should have double check my writing.
1) The expression (tan^3 θ) + (sinθ/cosθ) is equal to2) Simplify ((cos θ/1)+ (sin θ - cosθ/sinθ-1))^-1
3) The expression (cot θ)/(csc θ-sin θ) is equal to;
Is that clear?
Is that clear?
1 and 3 are clear.
Part of 2 is unclear: (sin θ - cosθ/sinθ-1)
What you wrote is ##sin(\theta) - \frac{cos(\theta)}{sin(\theta)} - 1##
Is that clear?
#1 and #3 are Clear enough.
Now, for #1.
Mark44 said:
1 and 3 are clear.
Sorry again. I am terrible at writing!
((cos θ/(1+sin θ )- (cosθ/(sinθ-1))))^-1
is this clear
Now, for #1.
That's good to hear that #1 and #3 is better. I am not a good writer...
And about #1?
And about #1?
Yes, What did Mark suggest for #1 ?
Regarding #1, don't do little bits and pieces of it. Start with the given expression and work with it to get it in simplest form.
(Note: I used x rather than ##\theta##, as x is easier to write.
Don't do this: tan^3(x) = sin^3(x)/cos^3(x);
Do this: ##\frac{sin^3(x)}{cos^3(x)} + \frac{sin(x)}{cos(x)}= tan^3(x) + ??##
This is not equal to ##tan^4(x)##.
I see. Do I multiply both numerators and denominators with the least common denominators?
Yes, if you insist on using this in "fraction" form, you will need a common denominator.
But Mark suggested writing sin(x)/cos(x) in terms of tan(x) .
In either case, you will eventually need to use an identity not included in the list you have under Relevant Equations ; one of the Pythagorean Identities.
I always found this stuff hard to recall off the top of my head as well and just found it much easier to just use Euler's formulas and just start factoring out exp(i*theta) whenever possible and simplifying. For two I would just get it into some form of one function divided by another like
A(theta)/B(theta)
then use Euler's formulas if you don't recall all the trig formulas that I can seem to remember and you should get an answer
YoshiMoshi said:
exp(i*theta)
It's very likely that the OP hasn't seen Euler's fomula yet. From the problems posted, he or she is just barely getting started with trig.
I solved it. Here are pictures:
Handwritten trigonometry simplifications on lined paper: problem 1 reduces tan²θ + sinθ/cosθ to tanθ·sec²θ through steps with cos²θ = 1/sec²θ; problem 2 simplifies a reciprocal of a difference of fractions to cosθ/2.
Handwritten trigonometry simplifications on lined paper: problem 2 reduces (cosθ/(1+sinθ) - cotθ/(sinθ-1))^-1 step by step to cosθ/2 inside a circle, and problem 3 starts from cotθ/(cscθ - sinθ) with intermediate fractions shown.
Handwritten trigonometry simplification on lined paper: cot θ over csc θ minus sin θ, rewritten step by step as cos θ/sin θ over 1/sin θ minus sin θ, then 1 minus sin² θ, cos² θ, and finally circled as sec θ via 1/cos θ.
Also, I am physics major and I am taking trigonometry class (hopefully I'll pass).
Cosmic-Kat said:
I solved it.
That all seems to work.
For the first one, a very useful formula is ##1+\tan^2=\sec^2##. So you can go ##\tan^3+\sin/\cos=\tan^3+\tan=\tan()(1+\tan^2)=\tan \sec^2##
This is where I was heading in post #4.
