Simplifying Trigonometric Integrals Using Trig Identities
  • Thread starter Thread starter Saladsamurai
    Integrating Sin
13 replies · 4K views
Saladsamurai
Okay so I am suposed to evaluate 2 of these:
1.) [tex]\int\sin^3(a\theta)d\theta[/tex] the solution manual looks
like it used a trig ID to do this. Why??
Doesn't [tex]\int\sin^3u du=\frac{1}{3}\cos^3u-(\cos u)+C[/tex] ?
So just use the u-sub [tex]u=a\theta \Rightarrow du/a=d\theta[/tex]
So it should just be [tex]\frac{1}{3a}\cos^3a\theta-\frac{1}{a}\cosa\theta+C[/tex] ?But they got: [tex]-\frac{1}{a}\cos a\theta-\frac{1}{3a}\cos^3a\theta+C[/tex]
Why the negative -1/3a ? What did I miss? Is it my formula?
2.) For [tex]\int\sin^4(3x)\cos^3xdx[/tex] they went from <---that to
[tex]=\int\sin^4(3x)(1-sin^23x)\cos3xdx[/tex]
How the hell does that make this problem ANY easier?! Is there a formula for ^^^that!Casey
You're using sin(u) like a variable, and integrating, which will certainly get you nowhere. One thing is that [tex]\int sin(u)^{3}[/tex] does not equal [tex]\frac{1}{3}\cos^3u[/tex]. You're going to have to use u-substitution, as you already have, and almost certainly some integration by parts.
Dick said:
I would suggest you use the trig identity sin(x)^2=1-cos(x)^2, followed by u=cos(x).
I'll try that now. But why is my formula not producing the correct result if I am using u=a*theta ? Shouldn't it be 1/a *{Pug it in} ?
[tex]\int \sin^3(a\theta)d\theta = \int \sin(a\theta)d\theta - \int \sin(a\theta)\cos^2(a\theta)d\theta[/tex]
The first term should be easy for you to integrate, for the second term, try a substitution of
[tex]u = \cos(a\theta) \Rightarrow \frac{du}{d\theta} = -a\sin(a\theta) \Rightarrow \sin(a\theta)d\theta = -\frac{1}{a}du[/tex]
After which the equation simplifies a little.
Use a similar idea for the second one.
So I got it using this. But I am still trying to figure out where I went wrong with the formula.
Casey
Casey
Seems to me like there is simply a typo in the book (the coefficient of the cos^3 should indeed be positive)
Not if you use the trig substitution; it is negative. It is definitely a mistake on my part.
Casey
did you mean [tex]\cos^{3}3xdx[/tex]?
I don't know what I meant?! I figured it out though.
Thanks!
Casey
i was trying to solve it for myself but then it saw that ... lol, is all good though.
