Simulation of Radioactive Decay
The discussion revolves around a chemistry problem involving half-lives and the decay of a 10.0 g sample of an unknown substance. The user graphed the mass of the substance over time, with specific data points provided. The main challenge is to determine the time when the mass reaches 5.00 g, which corresponds to one half-life. A formula is suggested to calculate the remaining mass based on the original amount and the number of half-lives. The user attempts to solve for the half-life using logarithmic equations but finds discrepancies when checking against the graph at different time points. There is also a suggestion that estimating the half-life from the graph might be a simpler approach, and the user contemplates how to reconcile the different calculated values for half-lives at various times.
Matthias32
Okay, I've got this problem in my Chemistry class. It's about half-lifes and all that. If this is the wrong place to post this, then somebody can move it I guess.
I've got a 10.0 g sample of an unknown. They give me the following info, wanting me to plot it on a graph. That's the easy part.
Time(yr)---------------Mass(g)
0----------------------10.0
20---------------------6.50
39---------------------3.80
60---------------------2.20
80---------------------1.20
100--------------------0.500
So I graphed it, but now they want me to locate the time when the mass is 5.00 g. Of course, this is the half-life. But how to find it...?
Then I need to check again at 2.50 g, but I can handle that part if I can just get some help on the 5 grams part. Thanks.
Matthias
Chemistry news on Phys.org
You know that after every half life, half of the remaining substance is lost.
So if you have 10 grams, 1 half life later, 5 grams are left, 2 half lifes...2.5 grams.
you could make an equation out of this,
(stuff remaining) = (original amount)*.5^(number of half lives)
so now you sovle it for the number of half lives it has had after a certain amount of time using the data given.
I did this, and my answer isn't quite agreeing with the chart when I check it though.
Just as an example, say you choose to find the number of half lives that have occurred after 100 years.
.5 grams = 10 grams * .5^(100 / x)
where x is the length of a half life. Solve for x by taking the log of both sides and applying some log rules. I found x = 23.17 years.
cheking it,
10*.5^(100/23.17) = .502, close enough.
But say you pick another date to find the length of a half life (20 year), the values for x do not agree.
Maybe they just want you to estimate it from the graph?
Yeah, later they ask some stuff about "do these two times completely agree?" How convenient. Then they ask how I could use them to approximate the half-life. :confused: Maybe the average or something.
  • · Replies 19 ·
  • · Replies 22 ·
