Sin and inverse sin multiplied
  • Thread starter Thread starter binalbean
    Inverse Sin
The evaluation of Sin^-1(sin(19*pi/7) results in 2*pi/7, not 19*pi/7, due to the range restrictions of the inverse sine function. The inverse sine function, Sin^-1, is defined to yield results only within the interval of -pi/2 to +pi/2. To solve this, one must identify the equivalent angle within this range that shares the same sine value as 19*pi/7, which is achieved by analyzing the unit circle.
  • Understanding of inverse trigonometric functions
  • Knowledge of the unit circle and angle equivalence
  • Familiarity with the properties of sine and its range
  • Basic algebraic manipulation of trigonometric identities
  • Study the properties of inverse trigonometric functions
  • Learn how to use the unit circle to determine angle equivalences
  • Explore the implications of function domains and ranges in trigonometry
  • Practice evaluating more complex trigonometric expressions
Students studying trigonometry, mathematics educators, and anyone seeking to deepen their understanding of inverse trigonometric functions and their applications.
binalbean
Evaluate the following:
Sin^-1(sin(19*pi/7) in terms of pi
i can't see any other way apart from the functions cancel to give 19pi/7 but checking on wolfram gives 2*pi/7, can anybody explain or help?
Thanks
Thanks
Welcome to PF, binalbean! :smile:
The inverse sine is defined to yield a result between -pi/2 and +pi/2.
So they do not just cancel.
The typical method is to draw a unit circle, find where the angle 19pi/7 is, and find the angle that has the same y coordinate but which is between -pi/2 and +pi/2.
The equation f-1(f(x)) = x is true only if x is in the domain of f, and f(x) is in the domain of f-1.
For example, ln(e-1) = -1, but eln(-1) is undefined. Here -1 is not in the domain of the natural log function.
And a nit-pick. The Sin-1 and sin aren't "multiplied". That is a composition of the two functions, or "function of a function".
Thanks very much for your help! :D
You're welcome. :)
This problem is an example that these conditions are not sufficient.
x also has to be in the image of f-1.
Btw, it's weird if f(x) is not in the domain of f-1.
