What Are the Singular Points of the Differential Equation w'' + z*w' + kw = 0?
The discussion focuses on identifying and classifying singular points of the differential equation w'' + z*w' + kw = 0, where k is an unknown constant. The primary singular point identified is at z = ∞, which is classified as irregular after a transformation x = 1/z reveals that the limit as x approaches 0 diverges. The participants also discuss finding the first term of the asymptotic solution as z approaches infinity, suggesting the use of a power series expansion w = ∑ a_n z^n.
  • Understanding of second-order linear homogeneous differential equations.
  • Familiarity with singular points and their classification (ordinary, regular, irregular).
  • Knowledge of power series solutions and asymptotic analysis.
  • Experience with transformations in differential equations, specifically x = 1/z.
  • Study the classification of singular points in differential equations.
  • Learn about asymptotic solutions and their derivation techniques.
  • Explore power series methods for solving differential equations.
  • Investigate the implications of irregular singular points on solution behavior.
Mathematicians, physics students, and engineers dealing with differential equations, particularly those interested in singular point analysis and asymptotic solutions.
Ice Vox
Hi,
I'm asked to find and classify the singular points of a function w(z) in the differential equation:
w''+z*w'+kw=0 where k is some unknown constant.
The only singular point I notice is $$z=\infty$$. Is that right?
I did a transformation x=1/z and examined the singular point at x=0 and found that the limit as $$x\to0$$ gives $$2-1/x^2$$ which blows up, meaning the singular point is irregular. Does that mean that the singular point z=infinity is irregular also?
It also asks me to find the first term of the asymptotic solution as $$z\to\infty$$ for each of the two solutions. Does this mean just put it in a power series solution $$w=\sum_{n=0}^\infty a_nz^n$$ and see what happens?
Thanks!
CWolf said:
Hi,
Thanks!
Wellcome on MHB CWolf!...
In general a second order linear homogeneous DE can be written as...
$\displaystyle y^{\ ''} + f_{1} (x)\ y^{\ '} + f_{2} (x)\ y =0\ (1)$
We have the following possible cases...
a) if $f_{1} (x)$ and $f_{2} (x)$ are both analytic in x=a, then x=a is an ordinary point...
b) if $f_{1} (x)$ has a pole up to order 1 and $f_{2}(x)$ a pole up to order 2 in x=a, then x=a is a regular singular point...
c) in any other case x=a is a singular point...
In Your case is $f_{1}(x) = x$ and $f_{2} = k$, both analytic in $\mathbb R$, so that there are no singular points...
Kind regards
$\chi$ $\sigma$
  • · Replies 0 ·
