Sinusoidal Current of .5 Amps (rms) & 5 kHz
The discussion centers on the interpretation of a sinusoidal current of 0.5 Amps (rms) at a frequency of 5 kHz. The correct representation of the current function is I(t) = 0.5√2 cos(10^4 π t), where the √2 factor arises from the relationship between rms and amplitude. The rms value, or root mean square, is defined as the square root of the average of the squares of the current over one period, leading to the formula I_{rms} = A/√2. This indicates that for an rms current of 0.5 A, the amplitude A is √2 Irms.
  • Understanding of sinusoidal waveforms and their mathematical representations
  • Knowledge of root mean square (rms) calculations
  • Familiarity with trigonometric functions, specifically sine and cosine
  • Basic concepts of electrical current and its measurement
  • Study the derivation of the root mean square for different waveforms
  • Learn about the relationship between rms values and peak amplitudes in AC circuits
  • Explore the implications of sinusoidal current in power calculations
  • Investigate the use of oscilloscopes for visualizing sinusoidal waveforms
Electrical engineers, physics students, and anyone involved in analyzing AC circuits and sinusoidal signals will benefit from this discussion.
AmagicalFishy
This is just a quick question:
A problem I'm working on says "a sinusoidal current of .5 amps (rms) and 5 kHz." Later, in the problem solution, [itex]I(t)[/itex] is written as [itex].5 \sqrt{2} \cos{(10^4 \pi t)}[/itex]. I think I'm simply misunderstanding something about the construction of a current function when given amps and such. Why is the current not: [itex].5 \sin{(10^4 \pi t)}[/itex]? Where does the [itex]\sqrt{2}[/itex] come from? I assume the cosin and sin are interchangeable.
Also, what is "rms"?
The time dependence of the sinusoidal current of frequency f and amplitude A is I=Asin(ωt), ω=2πf .
The rms value of current and voltage is abbreviation of "root mean square" the square root of the time average of the square of the current (or voltage).
The average of I2 is [tex](I^2)_{av}=\frac{1}{T}\int_0^T{I^2dt}=\frac{A^2}{T}\int_0^T{\sin^2(ωt)dt}=\frac{A^2}{2}[/tex]
So ##I_{rms}=\sqrt{A^2/2}=A/\sqrt2##. If you are given the rms current, the amplitude is A=√2 Irms.
ehild
If I could delete this thread, I would. Instead, I will answer it:
The [itex]\sqrt{2}[/itex] and "rms" are very related. The RMS value for some periodic current is the DC current that delivers the same average power. For sinusoidal waves of the form [itex]a \sin{(2 \pi f t)}[/itex], the corresponding RMS value is [itex]\frac{a}{\sqrt{2}}[/itex]. So, for a sinusoidal wave of RMS current .5 A, we just solve for [itex]\frac{a}{\sqrt{2}} = 5[/itex], where [itex]a[/itex] is the amplitude of the sinusoidal current.
Most information taken from: http://en.wikipedia.org/wiki/Root_mean_square#RMS_of_common_waveforms
Edit: Whoops! I was writing this while you wrote your answer, ehild. Sorry 'bout that.
  • · Replies 23 ·
