Sinusoidal Functions: describe transformations, sketch graph
10 replies · 4K views · last reply
Evangeline101
Exam question 46 text: Sketch a graph of y = 3sin(2(x − 60°)) − 1 for the domain −360° ≤ x ≤ 360°. Describe the transformations from the base graph of y = sinx. (6 marks)
none
-amplitude is 3
-period is 180°
-right 60°
-down 1
Rough sketch of graph:
Hand-drawn graph on grid paper of a sinusoidal curve with x-axis labelled -360 to 360 in steps of 90 and y-axis marked 1 to 4 and -4, with dashed horizontal line at y = 1 and dashed vertical line near x = 90, oscillating between 2 and -4.
I would like to know if the graph looks right, is there any improvements to be made?
blue_leaf77 said:
You got it wrong. That's the graph of y=−3sin(2(x−60o))−1y=−3sin⁡(2(x−60o))−1y = -3\sin(2(x-60^o))-1.
I re-did the graph:
Hand-drawn graph of a sinusoidal curve on grid paper, x-axis labelled in degrees from -360 to 360 and y-axis from -4 to 4, with a dashed horizontal midline at y = -1 and a dashed vertical line near x = 90.
Is this better?
Still incorrect. Start from ##f(x) = 3\sin(2(x-60^o))## which can be obtained by translating ##f(x) = 3\sin(2x)## to [left/right, it's your part to answer] by ##60^o## degrees.
blue_leaf77 said:
Still incorrect. Start from f(x)=3sin(2(x−60o))f(x)=3sin⁡(2(x−60o))f(x) = 3\sin(2(x-60^o)) which can be obtained by translating f(x)=3sin(2x)f(x)=3sin⁡(2x)f(x) = 3\sin(2x) to [left/right, it's your part to answer] by 60o60o60^o degrees.
Ok I have attempted the graph again:
The dotted curve is the original base function y = sinx, and I used it to help apply the transformations. The dotted lines show where the axes have been shifted.
Hand-drawn graph on grid paper of a dashed base curve y = sin x and a solid transformed sinusoid, x-axis from -360 to 360, y-axis from -4 to 4, with dashed lines marking shifted axes.
Is this an improvement??
Nope.
Your first drawing is almost correct. It's just the negative sign in front of the sine function that needs to be removed. May be it's better to draw the functions resulting from each transformation. So, you start from ##y=\sin(2x)##, which is a harmonic function of period ##180^o## and amplitude 1. Then draw ##y=3\sin(2x)##. Followed by ##y=3\sin(2(x-60^o))## and finally ##y=3\sin(2(x-60^o))-1##. This is the only way we can spot in which step you went wrong.
Okay, I have attempted the graph again, let's hope its an improvement at least :/
Hand-drawn graph of a sinusoidal curve on grid paper, x-axis marked from 360 to 360 in steps of 90, y-axis from -4 to 4, oscillating between 2 and -4.
blue_leaf77 said:
Yes, that's the correct one.
Thanks for the help! I really appreciate it :biggrin:
